I just reset my computer and my printer would not print can u help?
  • 838 Answers
You will need to install the driver for that printer. Please let us know what is the model and brand of your printer as well as your operating system/windows. We will try to help you to fix the issue.
Thanks.
Posted on Aug 21, 2010
Printer not responding
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 27, 2012 | Lexmark X3650 Printer
Not able to print
  4. Reboot computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 25, 2012 | Lexmark X8350 Print, Scan, Copy and Fax...
It want print anything!
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
Sep 12, 2011 | Lexmark C533DN InkJet Printer
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
Wont print
4. Reboot your pc.
Aug 21, 2011 | Lexmark X4550 AllInOne InkJet Printer
Why won't my printer print after I installed the software? It says its ready but nothing will print
4. Reboot your pc.
Aug 18, 2011 | Lexmark PhotoJet Z705 InkJet Printer
MY LEXMARK 1270 CANT PRINT NOR SCAN BUT ITS STATUS IS READY
2. Unplug and re-plug the printer into the power source to reset it.
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aKlcOJ. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 15, 2011 | Lexmark X1270 All-In-One InkJet Printer
My Printer Lexmark X4580 will not scan. I get the following message-Cannot retrieve Application List. Printing and copying works fine.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via the USB cable, disconnect your printer from your computer. Reboot your computer. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to scan again.
If that doesn't help, try to reinstall the printer software on your computer. This will help repair any corrupted files necessary for scanning or printing.
Jun 27, 2011 | Lexmark X4580 InkJet Printer
My lexmark printer is doing everything it's supossed to, but it's NOT printing. There isn't even any paper jammed. what could the problem possibly be?
Try to disconnect your printer from your computer. Then unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reconnect to your computer. Doing this usually fixes minor communication issues. If that doesn't help, try to check and make sure the print spooler service is running on your computer. Refer to this article: How to Restart or Reset the Print Spooler in Windows.
Apr 11, 2011 | Lexmark X2600 InkJet Printer
When printing duplex the even pages print portrait and the odd pages print landscape...
This could be a setting on the printer, in the driver on your computer, or the document you are printing.
First, try printing a different document and see if the problem persists.
Reset the printer to factory default settings, also referred to as a cold reset. HP has instructions on their website here: HP LaserJet 2300 Printer Series Resetting the Printer Cold Reset
You can also go into the printer driver on your computer and reset settings there, or uninstall and reinstall the printer.
Sep 08, 2009 | HP LaserJet P3005 Printer
19 people viewed this question
jasbo
jasbo
