Display from my Noma thermostat disappeared and I replaced batteries assuming they are gone. Nothing appeared on display. Can you pls confirm what is next step to reset or its some problem with thermostat? Ahsan 780-215-4522
SOURCE: Replace Transfer Roller
In the Phaser 6250 Color Laser Printer Service Manual (which I had to have emailed to me from my toner supplier since it is not available to the general public) I went to Chapter 6 - Error Messages and Codes. I had to reboot the printer. Here is the procedure.
Entering by rebooting the printer:
1. Turn the printer power OFF
2. Hold down the Back and Information buttons simutaneously and turn the printer
back on.
3. Continue to hold the buttons until the following message is displayed on the front
panel: Service Diagnostics V#.##, Initializing ....., and then release the buttons.
4. The front panel displays the Service Diagnostics Menu.
On the display is a menu. Find Transfer Roller. Press enter on this menu where it says Toner Waste (Not Full). Back out of the menu.
All of a sudden the machine came to life. You may have to turn off the printer and turn it back on again.
Good Luck
Posted on Jun 11, 2008
SOURCE: ABX-66
On most casio watch you can see AC (all clear) point , youy need to resset clock connecting this point with + on battery about 5 sec.
I have same problem but on my watch I do not see AC point. :)
regards
ststefan
Posted on Aug 14, 2008
  • 10 Answers
SOURCE: -AC appears in the display of chronotherm III
I have had the same problem- twice. It was a similar but different problem each time. The -AC means the ac control voltage isnt making it to the thermostat. In my case both times it was a switch in the control circuit that wasn't closing properly. The easiest was the front cover switch. If the front cover is removed from the furnace or has vibrated loose, the switch will open, preventing the furnace from running. The other instance I ran into was a flow switch on the exhaust blower which ensures the there is flow OUT the chimney. The switch wasn't functioning, so the furnace wouldn't start. The blower would come on for a short time, but the burners wouldn't light.
Hope this helps,
Posted on Dec 12, 2008
escapement
  • 2334 Answers
SOURCE: Pulsar NX14 Digital Display gone blank
Do not panic yet - all you need is the battery replacement.
Don't mind that the watch is less than a year old - it may laid in sellers store for a year or so and as the watches are not refitted with the brand new battery at the selling point, they may have underpwered battery much more quicker than you expected
Find your nearest watch repair shop and ask for battery replacement. Your watch will tick as brand new and will last much longer then before.
Do not forget to rate, please.
Posted on Jan 13, 2009
  • 1894 Answers
SOURCE: My thermostat has a blank display. I reset the
i thnk there must be some problem with the thermostat itself. check it out. its has got some firmware problem.
Posted on Jul 27, 2009
I have accidentally put the child lock on my washing machine but have mislaid my instruction manual. Please help.
A re-posting of a Fixya answer:
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Feb 23, 2018 | Bosch Washing Machines
My bosch frontloading washing machine when turned on there is flashing of spin and pause/off butons. we can't turn on the washing machine can you please tell me what the problem might be
Try pressing these buttons for 5 seconds, it will unlock.
OR
Press the "menu" button until you see"CHILD LOCK: ON" appear in the display. (if nothing is pressed within 10 seconds following this the menu will close and it will default to program in the display)
Once you see what I just mentioned in the display press the "select" button until"CHILD LOCK : OFF" appears in the display.
Finally by pressing the"start/pause" button the key symbol should disappear confirming you have successfully unlocked..
Pl click if helped.
Apr 28, 2013 | Bosch Washing Machines
Key on display wont start
Your washer is in the "child lock" mode, hence it won't allow any program. Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. If nothing is pressed within 10 seconds.following this the menu will close and it will default to program in the display. Once you see that in the display, press the "select" button until "CHILD LOCK :OFF" appears in the display. Finally by pressing the start/pause button the key symbol should disappear - confirming you have successfully exited the child lock program.
Pl click if helped.
Apr 11, 2013 | Bosch Washing Machines
Key showing on panel
Pl click if helped.
Mar 17, 2013 | Bosch Washing Machines
My machine show a 01 and a flashing key I try to do hold a button for 5 sec to deactivate but time tab it's not reacting with at is the prob
Pl click if helped.
Mar 14, 2013 | Bosch Classixx WFL 2066 Front Load Washer
White Rogers digital thermostat displayed "lo".
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. After replacing the battery you need to do the reset operation. If you need further assistance please contact us at 1800-284-2925.
Sep 24, 2012 | Heating & Cooling
Washing machine shows key on the display and won't start
Hello, Welcome to fixya.
The Key symbol means the lock has been activated some how.
Here`s how to deactivate it...
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry and good luck going forward.
Regards,
Macmarkus :)
Oct 20, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Display only stays visible at lowest illumination
Sounds like your display's backlight is dying. Your scfreen is in need of replacement. The higher ther brightness setting the faster it quits working.
Sep 25, 2009 | Dell Inspiron 1100 Notebook
Reset tire pressure
Ok this is very easy to do :
1- Switch ignition on. 2- make sure the standard display menu appears in the multifunction display. 3- Press button down or up repeatedly until the following message appears in the multifunction display
RUN FLAT INDICATOR
ACTIVE
REACTIVATION POSS.: +
4- Press "+" 5- The following message will appear in the display
TIRE PRESSURE OK NOW?
6- To confirm activation press "+" 7- The following message will appear in the display
RUN FLAT INDICATOR
REACTIVATED
8- Wait till "TIRE PRESSURE OK NOW?" disappears
You are done
Hope this helps
Jul 09, 2009 | 2006 Mercedes-Benz CLS-Class
Heating & Cooling Logo
473 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
