Question about Teac P-A688 Turntable
The belt on my turn table came lose
I own a Teac Full-Automatic Turntable System. I had packed it away because I was moving to a new town. When I unpacked the turn table I notice that the belt had come lose . I don't know how to put it back on
  • Allen May 03, 2008
    I would appreciate it if some one who is familiar with belt drive assembly for this model would assist me
01- Remove the rubber cushion.
02- Remove the Turntable Platter
03- Place your drive belt around the ridge inside the platter
(Make sure that it is not twisted)
04-Place your Turntable Platter back on the unit
05-rotate your platter until you can see a brass knob through one of the round holes in the turntable. (Your belt must be placed around the brass knob) The best way is to take a toothpick and carefully slide it under the drive belt and then pull it out enough that you can place it around the knob. I had the same problem and the above works. If you still have problems getting it back on contact me 352-377-1828......
Posted on Nov 17, 2009
  • Dawn Forgit
    Dawn Forgit Dec 21, 2013
    Thank you, thank you, thank you. At first I thought huh, but I tried your advice and poof, I'm listening to Captain Fantastic! Does that show my age?
  • 515 Answers
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Posted on Aug 31, 2009
I have a Teac LP200 and the turntable will no longer turn when I lift and move the arm over. Is there a belt to replace? How does one access it?
your unit has "The efficient belt-drive system provides accurate play and control" and normally the belt lasts for long time ..i.e at least 5 years..
If you sure that it is belt ,you need to take the turntable disc (should be a security pin in the middle ) than you can access underneath of disc or some models needs to access from bottom of the turntable ,inside the receiver..
just in case ,if you need detailed user manual in pdf format pls visit he URL below..
Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
User Guide for Teac LP-U200 View Table Of Contents»
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Jun 25, 2011 | Teac LPU200 Turntable
I have a DENON Fully Automatic Turntable System DP 297. I had been keeping it in storage in a box in my new home for some time. When I got it out and plugged it in, nothing happened. There are simply TWO...
hi,
from ur narration i think the ur turntables belt have some problem.it may be become loosend. if not put the belt correctly. first insert the belt on the round circle underside the plater( metal table). the put it on the turntable by pulling the belt with ur finger through the hole on the platter , engage the belt with the motor pully( brass spindle ). then plug it and try .
ok
Dec 21, 2010 | Denon DP-47F Turntable
Turntable belt is off.
Under the felt of the turning platter section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
May 16, 2010 | Teac GF-600 Turntable
I have a new Yamaha RX-V365 receiver and an older technics turntable, regardless of input setup I cannot get any volume from the turntable, yet all other inputs like CD, Tuner are fine....amp issues in...
Some turn tables do not have a built in amp, especially the older ones, the sound goes from the needle to the output. If the amp your are using does not have a designated phono, turn table, input it may not have the turn table pre-amp built in. Some turn tables have to be grounded to the amp to work properly.
Aug 30, 2009 | Teac DC-D2800 Shelf System
Have a teac p-a 400 turntable,that was just given to me. i see a rubber pad that goes on top of turntable, the turntable made out of metal, and a oversized rubber band. I put the rubber band around the...
I'm guessing that the belt is too large (stretched). Normally it should be small enough to stay on the platter itself. Install the platter and place the belt around the motor hub (white plastic), If the belt is too loose, it will just sit and not turn the platter. Try a new belt first as that is the least expensive option to try.
Keep us posted.
Dan
Apr 12, 2009 | Audio Players & Recorders
Arm trouble
If its automatic unit, it need belt to complete its mechanical cycle of loading and unloading its arm. You can check arm movement by spinning its table by hand.
Sep 05, 2008 | Teac P-A688 Turntable
Need assistance putting belt on turn table
"Put the thing on the other thing. There you go."
- Everyone trying to explain this to me on the internet.
May 27, 2008 | Teac P-A688 Turntable
http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things. if it keep coming off they can help you size a new one.
May 10, 2008 | Teac P-A688 Turntable
Teac P-A688 Turntable Logo
832 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
