Question about Dell Studio 17 Laptop
My dell studio battery wont charged. is it the battery, the charger or the plug in
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Aug 21, 2010
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
Oct 05, 2015 | Dell Computers & Internet
Dell latitude D420 wont charge when plugged in
If the laptop works without the battery, just the charger, the charger is OK.
Jan 13, 2014 | Dell Latitude D420 (DELLD420) PC Notebook
I have a dell studio 14. When i plug my ac adapter in to charge my battery, it charges for 5 seconds and then goes to idle. I have a brand new battery and charger, so I doubt it is either of these...
You didn't say, but I assume that you think the battery is not fully charged. Maybe it is?
If the power adapter is putting out the required voltage ~18v. and the battery is new, and still it can't charge, I would suspect the motherboard.
Feb 18, 2011 | Dell Studio 14Z Notebook
Battery not charging when connected to charger
If your notebook runs ok with the charger plugged in than it means that the changing filter or even the battery could be broken. You should check at your local dell service (they usually have one in every town).
Feb 11, 2011 | Dell Studio XPS 1640 Notebook
Dell studio 1535 not charging
Without testing the complete power circuit there is no way to know what needs replaced. the motherboard will most likely cost as much as a new laptop though. They are like the LCD screens. You can buy a new laptop for 4450 now days but to replace a motherboard or LCD screen you'll pay $500 to $700 not counting labor.
Jul 26, 2010 | Dell Studio 1535 Notebook
New battery wont charge back up
there is a problem with your charger. dell chargers have a habit of blowing. there is a small chip in them that tells the computer that it is ok to charge the batery, that little "safety feature" blows out and will no longer charge your battery. you will have to buy a new charger, either at a store like best buy (make sure it specificly says it is compatible with dell) or go to the dell website to order an "official" one. both options are unfortunately a little expensive, but your only option. i had the same problem with my xps1330.
Jul 19, 2009 | Dell Latitude D500 Notebook
Dell Studio 17 Laptop Logo
103 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
