Question about Kenmore Refrigerators
My kenmore refrigerator model number 52512100 SL2452623 Not cool on the right side. The range is fine. No waste that obstruct the airway. I appreciate the help you can give to solve this problem. Julio
applianceboy
  • 77 Answers
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
Posted on Sep 26, 2007
  • 1462 Answers
SOURCE: side by side kenmore refrigerator
defrost system not working. take back plate off freezer. checkdefrost heater and any stats mounted on the pipework
Posted on Sep 10, 2008
  • 531 Answers
SOURCE: Freezer and refrigerator are not cold enough.
you problem check and see if your fan condeser working best call service
Posted on Apr 05, 2009
  • 22 Answers
SOURCE: My whirlpool refrigerator (Model ET18DK) does not cool
Most likely one of two conditions are the root of the problem. Either the fan in the freezer is stalled or the defrost system has failed. The fan in the freezer should run any time the comressor is running; if it's not, there's your problem. If you can hear the fan, check for frost or snow developing across the back panel in the freezer. Local repair service could probably supply replacement parts quickly for defrost failures (most likely a bad terminator if defrost system isn't working).
Posted on Apr 25, 2009
  • 5 Answers
SOURCE: Refrigerator not cooling
the clicking sound you can hear is the relay or clixon as sometimes it is known by trying to start the compressor it may be stuck,first turn off the power to the refridgerator then turn the fridge so that you can see the motor,on the side of the motor you will see a small plastic cover remove it to expose the relaly remove it by pulling it towards you exposing 3 pins in a triangle shape give it a shake to free the solenoid inside the relay relace in the same way you took it off power up the fridge listen to see if you can hear the motor run constanly if it just starts and then goes of its more than likely the compressor is us
Posted on May 29, 2009
What is the coldest setting for a kenmore refridgerator
If your refrigerator section is not cold enough at the normal setting you may have a problem.
If you can't find enough information at the link below resubmit your question and include the model number. It should be inside the refrigerator section. It's usually on the upper right wall.
refrigerator not cooling but freezer is fine YouTube
kenmore refrigerator not cooling YouTube
Sep 07, 2014 | Refrigerators
My fridge _maytag (mtb1574de) is not getting cool in the fridge compartment. freezer is cool and i can hear and feel the fan circulatinf fine. the fan is not blowing hard in the fridge though. i already...
Some fridge freezers take the cold air from the freezer and moves it into the fridge via small duct in the back of the inside of the fridge and freezer . Empty frige and freezer , take plug ouy of wall and carefully remove involved panels taking note of any mechanical valves and order for reassembly. Clean and clear all airways and check for any blockages . Over loading of freezer can also obstruct airways . Whilst you are doing this you will allow a good defrost time for fridge and freezer airways . Hope this helps
May 10, 2012 | Maytag Refrigerators
The compressor runs and freezer is cold, however the refrigerator side isn't cooling well. Doesn't feel like any air is blowing in the fridge, only the freezer. I tried turning off/resetting the system...
Your model numbers are a waste of time...
Kenmore 5522 / 655224 / 55222 / 55229
Side by Side Refrigerator... PICK One...!!!
"The" fan...??
There should be TWO fans running...
and the FAN that REALLY make the difference in your
described symptoms ... will not run with the DOOR
open (your evaporator fan).
Possible issues:
Fan motor, blades/air blocked by ice, broken blade,
defective door switch or control board...
I always preach... giving a troubled refrigerator
a THREE DAY defrost... but the other day I found
a solid ice block sitting all SNUGGLY in the middle of
an evaporator...
If you are not willing to do that... (3 day defrost)
open it completely and have a REAL GOOD look
around the EVAPORATOR & FAN.
Never use HOT air... soft plastics can be easily ruined.
Take your MODEL NUMBER...
And look on:
Appliancepartspros:
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
repair clinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Happy hunting...
Carnac the Magnificent
Aug 16, 2017 | Kenmore 5522 / 655224 / 55222 / 55229 Side...
I have a kenmore refrigerator model 5533360 the freezer will not cool below 20 degrees.
check the back wall of the freezer. If there is frost on it then your fridge is not defrosting. Either the defrost timer, heater or thermostat. Is the fan in the back of the freezer running? if not then is obstructed, stuck or burned out.
Oct 27, 2010 | Kenmore 55603 Side by Side Refrigerator
Kenmore model 50503990 not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fsfj
Jun 09, 2009 | Kenmore 57029 Side by Side Refrigerator
Mar 22, 2009 | Kenmore 53092 / 53094 Side by Side...
Refrigerators Logo
61 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
