Question about HP Compaq 6720s Notebook
No sound in the inter speaker! except if I connect external speaker or headphones!!!
    Sergeant:
  • 238 Answers
As sound is coming to external speaker then need to check the connection or change your laptop speakers.
Posted on Aug 21, 2010
I connected an external device to USB 1 and watch movies with no problem, except I would like for the audio to play through my dvd player which has surround sound. With no audio o/p RCA connections on the...
you are using a stereo speaker so definitely you won't get surround sound, Most TV may have either RCA or 3.5mm headphone jack type, both serve the same function, what you need to do is just use a convertor check from this link.
May 16, 2011 | Acoustic Research 900MHz Wireless Stereo...
When conect speaker, the original tv speaker sound are off
Hello
You are connecting external speaker from your TVs headphone socket I thinks. It is quite normal that the internal speker will cut off when external a headphone is connected to the headphone socket. OK.
Jan 28, 2011 | Televison & Video
Speakers are not working in dell inspiron 6000
Please connect an external speaker or headphones and check if you get sound. If sound works then the issue is with the onboard speakers in the laptop.
If sound does not work with the external speakers or headphones then the issue could be with the sound card driver or settings.
Dec 25, 2010 | Dell Computers & Internet
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
Getting a cracking noise through the speakers
Sounds like the speakers are cracked (no pun intended) - damaged cones. Connect external speakers or connect a headphone to the headphone jack to see if you get the same sound. If not, then the speakers themselves are damaged.
Nov 01, 2010 | Pioneer PDP-5070HD 50 in. Plasma...
How to connect headphones to this tv.
The only way to accomplish this will require an external amplifier.
Connect the program out to the input of the external amp and use the headphones from there. Disconnect the speakers or turn them off in the audio menu.
Hope this helps,
Dan
Jul 11, 2010 | Panasonic TH-42PX60U Television
I have no sound on my hp pavilion entertainment pc laptop. No sound, but a click each time I mute or unmute. i have re-installed drivers. All checks out -- except no sound.
you have to check the audio controllers from control panel too,, and make sure,, you are well connected to external speakers,, if you have,, or else first make an check with headphones for sound checking,, then you can analyse if it works,, then there internal speakers problem.
Sep 27, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Low sound in headphone
I would say it is because the unit does not have a built in amplifier. The speakers are powered PC speakers of studio monitors I am guessing. Try plugging the headphones into the headphone jack of the speakers if they have a headphone jack or try a set of powered headphones out of the Edirol and see if it helps.
That should remedy the problem.
Dec 27, 2008 | Edirol UA-4FX External Sound System
HP Compaq 6720s Notebook Logo
161 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
