Question about Garden
Scotts riding mower 2046H mower will start but when you let off of the brake or engage the mower blades it will die. What is the problem?
I see you posted this a long time ago but maybe someone else is having this problem and needs this fix. I had the same problem and came across this solution accidentally. Although not a permanent fix, if the blades are off and the parking brake in lock position, you can start normally. After starting, unplug the electrical connection under the foot pedal bar located under the chassis, on the right side middle. Then go to left side and unplug the electrical connection on that side in about the same place. Both connections are above the deck but below the chassis. I pull the cords up and loop through the hole in the chassis they come from to hold in place. You can then operate the parking brake and mower deck after doing this. These must be plugged back in upon restarting.
Posted on Aug 06, 2013
Check the under seat switch.
Also there is a switch on the LH brake pedal.
Also, there is a switch (apparently) on the blades engage lever.
Details of these I am unsure, but mine will not start without the brake depressed and the blade engage pulled aft(if left with no aft pressure on lever, it will not turn over)
I’m happy to assist further over the phone at https://www.6ya.com/expert/christian_22ba4e8e317839fa
Posted on Jun 07, 2011
I am having the exact same problem...did you ever find a solution?
Posted on Sep 12, 2010
Why does my riding mower die when put in gear or engage the blades
Check out the grass box safety switch. if not fully depressed it will apply brakes to the blades when in gear. Most mowers are designed with a safety switch to stop the blades, or forward motion if the grass box is not fitted correctly.
Aug 23, 2015 | Garden
When blades start to engage it dies what could that be
you have a bad safty switch replce it the one that goes to the brake start switrch
Jul 01, 2014 | Cub Cadet Street Sign- tractor lawn riding...
What causes a riding mower to die when engaging the blade
safety switch in the seat and in the brake. if one of those is open, engine will die when you engage the blades. Owners manual should have wiring diagram so you can bypass switches to test (if you have brake applied and are sitting in the seat and that is when it is dying).
May 04, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Scotts riding mower 2046h mower
engine rpm would be the only other thing. or you have the belt routed incorrectly. are the blades upside down? I see that on an almost daily basis with customer units.
Jan 08, 2018 | Garden
Mower dies when directional pedal ( F/R) or engageing blades
check the safety switches start with the one on the pedal
May 16, 2012 | Garden
Scotts 1642h riding mower Ignition Switch, Seat Switch or Wiring Problem?
Will run with no one in seat if clutch is depressed but will not run with clutch depressed and blade engaged with no one in seat. Could be your pto safety switch is bad. Maybe battery new but not charged try charging with 2 amp charger overnight and see if that helps. Maybe diode in charging circuit bad.
Sep 07, 2017 | Craftsman Garden
Replace switches & clutch. When brake is release everything dies. Ineed a wiring diagram.
There are a few safety switches on a riding mower. One is the brake clutch, which must be engaged to start mower if not in neutral for a manual transaxle. Another is a blade engaged safety that will not allow you to start it with the blades engaged and the other is the seat safety that prevents starting if the brake is not engaged.
If the seat safety switch is messed up and you release the brake it will kill the engine. I would start there.
I hope this helps get you going.
Aug 03, 2011 | Garden
I have a husqvarna riding mower and when i turn it on and release the brake the mower dies and when i put the blade on or give it gas it dies, but for the most part just releasing the brake after letting...
It sounds like the seat switch is not working. This switch must be made by a person sitting in the seat for the brake to be released or for the blades to be engaged. It is possible to start the mower with the switch open.
Gary
Jul 03, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a scotts riding mower model 2046h 46'' cut and do not know how to change the transmission belt. Thanks for any help.
To whom it may concern, I have a Scott's 2046H lawn tractor # GX2046S042396, I replaced the arm #GY00244 which the original piece was found broken. Now I have the unit back together, but I have no drive, forward or reverse. I checked the belts and pulleys, belt is tight and the pulley's are intact and functioning. Any ideas as to what I should check or do?
Apr 18, 2010 | Garden
Replacing deck belt
Here ya go.
Jul 14, 2009 | Garden
Garden Logo
335 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
