Question about HP Office Equipment & Supplies
Hp deskjet D1663 makes rattling noise when starting to print
  • Derek J Pollard Aug 21, 2010
    Hi Daniel,
    I have checked the items you recommended. They are fine. It seems to be related to the print head wiper tray which is gear driven. What senses the position of the print head wiper tray. If it does not send a signal when retracted then the drive will continue to force it against the stop, causing it to jumop gears ? That is precisely what is happening but I cannot locate the sensor. Regards, Derek.
  • 857 Answers
To fix this problem, download the service manual which shows how to remove the case. You’ll need a phillips screwdriver and some machine oil or something similar to Z-Max. When the printer is apart and you’re facing it, on top there’s a compartment with a metal cover plate (shield) held by two screws. To the left is a spring loaded switching system that rocks into position when it’s called, and presses on the tab of a leaf switch. With the printer plugged up, you can press on the leaf switch which will engage the printers system, causing the printer to attempt printing. During this you’ll hear the screeching sound you’re describing. This is your test procedure during this repair. Next, notice the two multi-wire connectors at each end of the compartment. One bundle runs across the top of the compartment and connects on the other side. Remove both connectors and the two screws that hold down the shield; one holds down a metal pressure tab, also to be removed. This releases the shield exposing a small circuit board that has a control IC and a small motor. Three screws holds this circuit board to the printers plastic casing. Taking care not to handle the circuit traces (IC Static Protection Protocols), remove the screws and remove of the board. On this board is a small motor with it’s flywheel held down by a square weight and a pressure tab. Remove the top tab and the weight, turn the plastic guide to the side, and lift the flywheel away from the motor. Apply the lubricant to the shaft of the flywheel and reassemble the system. Try your switch test. Chances are, it’ll work without all that screeching. If you get that far, trust me it will be ok.
Posted on Aug 22, 2010
  • 4,323 Answers
Hi
The sound you are getting is due to a loose carriage or the loose chrome rod inside the printer. Open the carriage door and remove the cartridges, now check if the carriage is loose. Inspect the rod for any irregularities. If these are fine then make sure that there are no stuck pieces of paper inside. Also, check the ribbon cable attached with the carriage.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 21, 2010
  • Daniel Scott
    Daniel Scott Aug 21, 2010
    Hi
    Open the cover and unscrew the screws that sit on each side. Then, unclip the small button panel on the right, and bring it inside the printer. You will notice a flat light-gray plastic lock that you can push to unlock the top plastic cover on each side of the printer. Push them to unlock the front. On the back, remove the gray panel, and push the gray flat plastic locks towards the front of the printer to unlock the back. You should be able to remove the gray cover. Now you would be able to access these gears.
    Daniel
  • Derek J Pollard Aug 22, 2010
    Sorry, You must be talking about a different model printer. I asked you how to access the wiper tray end position sensor and you have given me info pertaining to some other printer.
Hp deskjet D1663 Pulls papers non-stop and output is blank
Perform a head cleaning process in you printer, If it is not helping the print head is faulty, take it to service shop
Apr 22, 2014 | HP deskjet d1660 inkjet printer - color -...
How do I remove the cover from an HP Deskjet 5740 printer
No need to open its cover. that is normal, when the print is first start the mechanical parts are re-adjusting and re-alignment its system to start printing.
Sep 11, 2012 | HP Deskjet 5740 InkJet Printer
How to reset hp d1663 ink levels
hp D1663 is my printer, problem is does not print, After Installing drive for first times it works, ink level is fine.
But after 3rd or 4th printing it does not print at the same time ink level problem is shown in the display popup....so again uninstall print driver & same problem repeats...please help?
Jan 27, 2012 | Office Equipment & Supplies
HP Deskjet D1600 Printer series to work with my Comp W XP I dont find the CD
You can download the s/w from the below mentioned link :
HP Deskjet D1660 Printer :
Select windows on this page :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3811075&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
HP Deskjet D1663 Printer :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3837084&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
HP Deskjet D1668 Printer :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3960828&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Feb 25, 2011 | Office Equipment & Supplies
As looking for HP Deskjet D1663 Printer Driver for free
You can download the driver on this link http://www.siliconguide.com/drivers/device/1126/.
Hope it may help you.
Have a nice day!
Feb 09, 2011 | HP Office Equipment & Supplies
Printer won't print, just rattles
It needs service. open the casing and clean the printer sensor and rod with iso-propyle
reply if done
cheers
Jun 24, 2009 | HP PSC 2175 All-In-One InkJet Printer
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
Hp Deskjet D2360
my pc cannot recognize the printer
May 14, 2008 | HP Deskjet D2360 InkJet Printer
189 people viewed this question
Seeker5211
Seeker5211
