Question about Mitsubishi Televison & Video
Mitsubishi WD-52525. I have been working on this tv since I got it from a friend in pieces. He replaced caps and said it should work. Since then I have replaced fans, switches, and put it together so it finally fired up. The power came on, the fans are running , then after about a minute , it shuts down and gives me the solid red lamp light and error code 34. So, is it the lamp, the lamp ballast or the dreaded .....capacitors ? if so, which caps. I have the TV reair world disc and the capacitor repair kit, so do I just replace the caps that it outlines in the kit ? I hope it is just a lamp. Thanks
  • Jay Keating Aug 21, 2010
    Thanks !
    Thanks Ladywinn ! you made my day. I have no Idea the age of the lamp in the tv but it looks good. I found one for $ 86.00 including housing. I will order it now that a guru has recommended that I do it ! Thanks !
  • Mitsubishi Master
  • 5,138 Answers
Replace the Lamp,Mats Electronics has them for $99.00
Also Google to this website and type in your model number they will list Parts/Numbers and Prices,They also have Free Service manuals that you can print out while online Sometimes
it will be listed at top of page on left hand side WD52525pdf.
click that if they have it - Encompass Parts Distrubtion
1-800-638--3328
Posted on Aug 21, 2010
  • ladywinn
    ladywinn Aug 22, 2010
    If you should ever need any advice Please feel free to ask.Thank You and have a Nice Day.
    Please be sure to go to the website I told you about ,I went back to look and they do have Free Service Manual for this Model.You can Print it out online.
Hi i have a mitsubishi WD-52525 and the timer light just keeps flashing and the tv wont power on....whats wrong with it?
Check for bad cap on DM & FMT modules 1000uf at 25volts caps to E2P module.
Credit: http://www.repairworld.com
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Tv stays on for about 3 minutes the shuts off
If it is Mitsubishi WD-52525 DLP TV then it sounds weak lamp problem in TV and TV needs lamp replacement.
How old is this TV and did you replaced lamp recently?
Lamp replacement is written in user manual of TV and it is easy work.
Please buy Mitsubishi original lamp for TV safety.
Thanks.
Oct 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 picture problem
you didnt mention which two boards you replaced the caps on however each board in the chassis has the same capacitor issue. Sounds like you need either of the four V26 Repair kits. The FMT repair kit, The signal Repair kit, The Terminal 1 or the terminal 2 repair kit
Jun 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green timer light on mitsubishi wd 52525
disconnect the connector for the front switch control board. Try turning it on with the remote. If it works replace that board, also look for bad caps on the small signal board. they're 1000Mf 16v
Mar 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 Red Status Light After Cap Replacement
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
Sep 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I need help with my wd-52525
Blinking Problem
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
May 14, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 Lamp ballast
i am sending a response to your request to your email address.
May 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Open Questions:
Televison & Video Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
