Question about Whirlpool GH7208XR Convection / Microwave Oven
Need to know what error f2 q1 is. on model gh7208xry
  • Whirlpool Master
  • 9,098 Answers
I have a whirlpool gold over the stove top microwave that control panel starts beeping and setting itself. How to do I fix model gh7208xry-3?
This answer is for model GH7208XRY3. The support page for your model is here, and you can view or download the owner's manual and installation instructions.
The exploded view with parts list is here.
You will need to order either the door control assembly, part number W10115584 for $280.35 from the Pros here, OR you can order the whole door. It costs more, but it easier to replace. It is part number W10327332 and runs $428.68 from the Pros here. (Prices subject to change)
Feel free to contact me for further info.
William E. Miller
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 15, 2017 | Whirlpool Microwave Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
F2.q1 touch fema
This error code means you have a defective membrane keypad ("touch panel").
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 18, 2011 | Whirlpool Microwave Ovens
Kitchenaids microwave error message F2.Q1. What to
F2.Q1 Not reading keypad
inputs
1. Unplug microwave oven or disconnect power.
2. Replace the user interface board (UIB).
3. Replace the door control assembly.
4. Replace all parts and panels before operating.
5. Plug in microwave oven or reconnect power.
Many of the error codes may be solved by power cycling: unplug microwave oven or
disconnect power. After one minute, plug in microwave oven or reconnect power.
i found this info on a tech sheet hope this helps, let me know how it goes... some of those electronics had 5 year parts warranty i would check that out....Also u might be better of buying a new one if its out of warranrty as some of those boards are expensive, obvioulsy unplug unit first try to reset it self.
Feb 14, 2010 | KitchenAid KHMS2050SSS Microwave Oven
My new Whirlpool oven Model number GBD 279 PVS02 error code EO F2
F2 E0 is a shorted keypad. Replace the keypad which is your entire touch pad. In rare cases your ERC or electronic range control can also be bad, unlikely though. Hopefully this is still under warrantee as the part alone is over 150.00. I recommend you have a technician replace this as most parts houses will not warrantee a electical part if a customer installs it. Good Luck, Appliance Specialists.
Dec 15, 2009 | Microwave Ovens
F2 Error
F2 is a membrane switch error.
2. Replace membrane switch.
3. If problem persists, replace electronic control.
The answer to your question is YES. I would venture to say the PART is - but not the labor. You would need to read your warranty to confirm.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 11, 2009 | KitchenAid KHMS155L Microwave Oven
Kenmore microwave model 63792 displays F2 error message
The F2 error code on your microwave oven is a membrane failure.
It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Aug 21, 2009 | Kenmore 63792 Microwave Oven
The microwave is displaying "-F2-" on its screen and will not otherwise work. What do you think the problem is?
It is a bad keyboard error code. Try this, unplugg the unit, open the control panel and disconnect the ribbon cable from the control board, plugg back in, if f2 comes back on the board needs replacing, if it does not, then the problem is with the keypad.
F2 means you have a shorted membrane keypad, which would have to be replaced.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
good luck
dont forget to rate the service......
Aug 18, 2009 | Whirlpool MH8150XJ Microwave Oven
Error code F2.Q1
Not sure what you mean by "Q1 Touch FMEA" above, but F2 error code indicates a bad keypad or sometimes a bad sensor.
Since it's brand new I would first consult the manual. If you don't have it still, you can download it from the owner center here: http://whirlpool.com/custserv/index.jsp
If you still have trouble, since it's new, it should obviously be under warranty, so I'd contact them (same page as shown above) to get it repaired under warranty.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 01, 2008 | Whirlpool GH7208XR Convection / Microwave...
Whirlpool GH7208XR Convection / Microwave Oven Logo
320 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
