Question about Alpine Car Audio & Video
I have 2 alpine type-r 12" subs and one of them is making a very loud high pitch noise almost like the car is shaking but its coming form the sub its self. the cone isn't damaged and its only makes the sound on high pitch notes.. anything low notes it sounds fine. i was wondering whats the problem could be., thanks!
  • 18 Answers
SOURCE: Audio system makes extra noises... pops
most of the time when a high power amplifier starts making noise not all the time but every once in a while or even all the time its the ground, if the amp turns on its not the power cable. try moving your ground to a different location or try using double grounds. the better the ground the better the sound. and as for turn on pops, put a toggle switch inline on your rem wire and turn it on after the car is started.
Posted on Oct 04, 2006
zzedly
  • 300 Answers
SOURCE: bridging to 12 inch kicker competition subs to my 1000 watt alpine 4 channel amp
I'm a bit confused. For Alpine amps, the "M" prefix is for monoblock (aka single channel) amps and the "F" prefix is for multichannel amps. The only M550 I find is an MRD-M550, which is a monoblock, not a 4 channel like you say.
Unfortunately, I can't give you accurate help until we know weather it's truly 1 channel or 4 channel. Then I'll be glad to help!
Posted on Mar 07, 2008
  • 11 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Posted on Jan 15, 2009
sticky92505
  • 77 Answers
SOURCE: High Pitch Noise Coming Out Of My Subs?
sounds like it could be a warning sound that indicates either a short or a bad connection and is tripping the safety warning. check all speaker terminal connections and connections on the amp to make sure there is nothing loose or touching
Posted on Feb 18, 2009
ctc1234
  • 26 Answers
SOURCE: I have a kicker l5 12
It sounds like the voice coil may have been damaged in which case you'll hav e to get a new speaker.
Posted on Jun 07, 2009
What box should i use for alpine swr-12d2
What size box does this sub need in a sealed box & a ported box. If you have room use a ported box that fits your subs. Probox & other brands may have the perfect box for them. I would tune the box to 40hz if you like loud tight bass.
Jan 24, 2013 | Alpine 2 Swr-12d2 Car Ausio 12" Dual 2-ohm...
I have two 12" Alpine Type-R subs running on a
9check connections inside sub enclosure(assuming they are in one)mine loosen up after running them hard for months on end.they act the same way yours are.
Jan 24, 2018 | Alpine Type-R SWR-1222D Car Subwoofer
Popping noise on my 12" type r subs
The subs are making that sound when the bottom out + when they reach full excursion be careful if it keeps happening eventually your subs will fail because you will end up damaging the subs voice coil.
Happy Booming
Apr 20, 2010 | Alpine Type-R SWR-1222D Car Subwoofer
Car stereo
check your amp to see if its on high or low setting in order for it to bump it needs to be on low thats all the bass settings and you shouldnt hear the words come out of your subs
Nov 01, 2009 | Car Audio & Video
Jan 27, 2009 | Fusion FEW12PK Car Subwoofer
Alpine MRD-M1005 Subwoofer Amp Problem
He may be right! You might try finding a new source of contact for your ground cause it may not be sufficent enough to ground to, also make sure that no wires from the back of your radio have any wires sticking out touching other interfering things that could possibly be causing the noise
Sep 14, 2008 | Alpine MRD-M1005 Car Audio Amplifier
High pitched noise comin out the sub
You may have a ground loop issue. Make sure your ground lead is as short as possible (<1ft, if possible) and that it is mounted to a nice, clean (unpainted) spot on the vehicle. If you have multiple amps, try and ground them to the same point.
Mar 07, 2008 | Fusion FEW12PK Car Subwoofer
High pitched noise comin from sub
if sound also goes away when throttle is released and sound returns when throttle is pressed down, then you have engine noise from car engine electronics. In older cars, this was quite noticeable when the cars had distributor caps. The electrical noise caused by arcing required for the spark plugs could be your issue. It is resolved with a noise filter which gets wired inline leading to your in-dash deck and power amp (if you have one). The filter can be found many places including Radio Shack and Crutchfield.com. First find your total wattage draw for each component of the sound system (deck and amplifier), then divide by 12 to get current draw through filter. Purchase that size filter or larger.
Feb 12, 2008 | JBL GT1041 Car Subwoofer
Car Audio & Video Logo
12 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
