Question about Jet 3 Ultra Power Chair
Not sure if jet 3 is charging - Jet 3 Ultra Power Chair
  • 692 Answers
Does all your lights on the joystick come on after charging? If you can have someone look behind your chair while still plugged in for charging, the green light on the charger will be lit if the batteries are fully charged. They will have to kneel and look under the shroud to locate the charger they will see the light if it is on. Also check the meter on the rear of the chair the meter should read zero when the chair is plugged in and fully charged. I fyour chrger is working then if the chair does not stay with power for what was normal then new batteries are probably needed
Posted on Aug 22, 2010
Why isn't chair charging?
1. Make sure that your chair is turned on.
2. Make sure that the brake release levers are in the drive position. See owner's manual.
3. Make sure that your chair is charged. 4. Make sure that your chair is not plugged into the wall.
Aug 04, 2015 | Jet 3 Ultra Power Chair
I changed the batteries in the jet 3 ultra. Chair will work but batteries will not charge
Wall outlet bad? Charger not turned on/plugged in right? Something disconnected? Bad battery connection? Blown fuse in chair or charger? Bad battery or batteries?
Aug 09, 2014 | Jet 3 Ultra Power Chair
The batteries in my mother in laws Jet 3 are about 6 months old and charge up to nearly 13 volts,but the travel is now about one third the distance that it should travel bfore losing charge. what should...
If you have someone do a load test on her batteries I'm sure they will find one weak battery that does not stand up under the load. Make sure that the batteries are fully charged before they do the load test and if one or both of the batteries drop more than a volt and a half under load then they must be replaced Most batteries are under warranty for 6 months lets hope you made it under the wire. Now if Medicare paid for her chair then they will pay for a set of new batteries contact the provider where she got her chair for repair Hope this helps
Apr 28, 2011 | Jet 3 Ultra Power Chair
Jet 3 will not turn on but when you plug charger cord in it will light up the entire length of the battery indicator when you push the switch. Chair will still not move. Controller is a PG Drives Pilot...
the batteries are not charged and need to be replaced. The reason you have lights is because the charger is supplying power to the chair and the chair will not move when the charger is plugged in because of the inhibit function. Replace the batteries and make sure you charge before use Hope this helps
Apr 15, 2011 | Pride Used Mobility Jet 3 Power Wheel...
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Oct 30, 2010 | Jet 3 Ultra Power Chair
My grandfather's jet 3 power lights won't come on... It is plugged into charger and I have hit reset button
Make sure the batteries are charged, and then have them tested with a load tester. Also check every wire connection to make sure that they are snug.
Oct 17, 2009 | Jet 3 Ultra Power Chair
The battery on my jet 3 will not charge
you need to replace both batteries, their called U1 batteries (35 AMP-Hour)
Jun 08, 2009 | Pride Mobility Products New Pride Mobility...
Jet clean system will not clean.
I had the exact same problem. Then I put more solution in so that it was just above the MAX line and it worked fine. So make sure you have enough cleaning solution in the system and it should work great.
May 20, 2007 | Norelco 8160XLCC Electric Shaver
Jet 3 Ultra Power Chair Logo
199 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
