Question about GE (PSS26MSRSS) Side by Side Refrigerator
Model GSS25KSWA SS Our ice and water dispenser is sticking and continues to dispense after glass is moved away. We have to swith to the other setting to stop it...EXAMPLE-After dispensing water it will not stop and then we have to switch to ice to stop it. Ideas? Thanks
  • 100 Answers
SOURCE: psc23sgrd ss ice/water dispenser not working
It is possible. When you put hit your glass against the paddle to you hear the switch click? And can you still select between water, cubed, and crushed ice? Also does the light by your glass come on when you but your glass against the paddle?
When you put your glass on the paddle it pushes in a microswitch. That microswitch will power the light if it is working and also sends power to the board you are talking about to dispense ice or water depending on what you have selected.
Posted on Nov 03, 2007
SOURCE: Jenn Air JCD2389GES ice dispenser problem
my ice maker is not making ice.
Posted on Mar 26, 2008
  • 1073 Answers
SOURCE: GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Posted on Apr 12, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
SOURCE: GSS23LSTA SS WILL NOT DISPENSE ICE OR WATER
Thank you. The part number WR60X231 is showing as a condenser fan blade on repairclinic.com. Is this part number correct?
Thanks!!!
Posted on Nov 11, 2008
Why does ice dispenser stick?
I dont know what brand you have. But there is a springlever to return the lever to closed posision. Eather the return spring/mechanism is broken. Or has become loose from the fastnerclips holding it in place. I have also seen that ice is the reason for this. Iceing around the very top of the lever.
Feb 17, 2016 | Refrigerators
My ice dispenser keep shooting out ice after I moved glass away. The ice comes out in handfuls.
Sounds like there is still ice in the Shute, the unit is design to clear the shute so ice want freeze in the shute. Just touch and allow the shute to clear. The shute doesn't get as cold as the rest is why this happens. There is a micro switch near the handle that might be sticking, but seldom does.
Jan 03, 2015 | LG LFX25960 Bottom Freezer French Door...
Model GSS25TSRE SS Water dispenser does NOT work, but the ice dispenser does dispense ice. Looks like the freezer compressor is NOT working. Help!
Most likely you main control board is bad.... Replace it and your troubles will go away... It is located inside back panel of fridge on the right hand side if you are looking at the back. Sometimes if you unplug power and remove board you can see burnt spots on the back of it but not always.
Nov 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser is not working
Does it make ice? If it makes Ice, then you have water to unit. If No Ice and No Water, check water supply. Otherwise, you could have a bad water valve. Remove valve and the line coming off of valve to water reservoir try to dispense water and if valve is good you should have water coming from valve. (have a bucket or bowl handy to catch water).
Mar 28, 2010 | GE Refrigerators
Have a SS #GSS22WGPEWWW Ice not coming out
Try taking ice pan with auger out hold door open and press light switch for the door in while someone presses dispense ice. I want to see if the motor is turning behind the auger ice tray. The door switch has an interlock and when door is closed the dispenser controls should be functional. When open this disables water and ice dispenser. waiting on your response, Sea Breeze
Jan 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Replacing water fitting assembly
water dispenser continues to run too long after removing glass
Oct 23, 2008 | Refrigerators
Psc23sgrd ss ice/water dispenser not working
Nov 03, 2007 | GE Profile PSI23NCR Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
99 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
