Question about Hotpoint Dryers
My dryer runs but does't get hot It works but it does't heat up to dry .
  • Hotpoint Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Kenmore dryer MOD# 110.61402310, Dryer heats up and is SUPER hot. Clothes are to hot to take out after. Seems like timer is messed up because it will run until you open the door. Only has one heat set
OVER HEATING HAPPENS ONLY IN ELECTRIC DRYERS NOT GAS DRYERS.... HERE IS A VIDEO FOR HELP ON THIS..
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Oct 28, 2014 | Dryers
Amana ALG443raw gas dryer
sounds like the thermostat is shot..do you fix this sort of thing yourself?
Mar 17, 2008 | Amana ALG443RAW Gas Dryer
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
Dryer not heating
There is a heating element or thermal coupler that go out on Electric dryers.
May 29, 2010 | Maytag MDE2400A Electric Dryer
Dryer runs but does not get hot and dry
It runs since the motor is still working and turning the drum. No heat since the heater element is broken so no heat got produced to dry clothes. Replace the heater element to correct the problem. Good luck
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
My GE Profile Harmony Dryer is no longer Heating
Does it get hot when you turn it on, and then never gets hot again while its running? On my dryer the solenoid broke, when the dryer was cold it worked and the dryer operated properly because the dryer and solenoid were cold and the solenoid wire was closed, when the dryer was hot enough the solenoid opened and the heat would not restart. the solenoid is a coiled wire which is used to open the gas valve.
Dec 28, 2009 | GE Profile Harmony DPGT750EC Electric...
Our kenmore eliite HE4 gas dryer keeps shutting off after a few minutes of running no mattter what heat setting we put it on. On air dry mode it works. Is this a high heat sensor problem? The unit is 4...
You didn't mention if the dryer is getting hot.
If is getting hot, then shutting off, I agree with you.
If it is NOT getting hot, I would suspect the IGNITER ASSY
Dec 13, 2009 | Kenmore Elite HE4 Electric Dryer
Is not heating
i think when this happened to my sister it was the heating coil. her dryer caught on fire. don't run it unattended.
Aug 01, 2009 | Kenmore 700 6972 Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
