Question about Pentair Challenger High Head 1.5 Hp Pump Up Rated
We have a Pentair Challenger 1 1/2 switchless motor. While running it is very loud...is this normal?
    Problem Solver:
  • 10 Answers
Check amount of water pumping if pot is not full you could have somthing in the impeller like small leaves
Posted on Sep 01, 2010
Pentair challenger 2HP pump start capacitor
check the bump on back of motor remove cover take picture of wires then get new one from electrical supply store
Jun 24, 2014 | Pentair 2 hp Challenger Pump
My pentair 2 hp challenger pump turns off after 4 second
since it's a new install is voltage set correct on motor ? this seems possible due to short run time you report
May 04, 2014 | Pentair 2 hp Challenger Pump
Pentair challenger hums but does not spin
check wiring see side of motor 120 volt vs 240 volt if 120 volt have to move some wires
Oct 02, 2012 | Pentair 2 hp Challenger Pump
Challenger pump leaking at the band
You may need a seal plate o-ring or you may have a shaft seal leak. See if you can determine if there is water running down the outside of the seal plate from where the motor mates to the seal plate.
Feb 15, 2012 | Pentair 1 HP Challenger Pump
Pentair challenger 1 horse pump; motor running ok, sounds a bit noisy, now does not pump at full force, water does not fill the pot even after primed start, pressure guage reads 0 psi before read 20...
check the impeller for debris. you will have to take the metal band off that connects the wet end to the seal plate. inspect the impeller for debris. lube all o-rings and reassemble. if that does not work, investigate a blockage in the suction side plumbing.
Aug 12, 2011 | Pentair 1 HP Challenger Pump
I have a 2 HP 230 V AC Pentair Challenger series pump for my pool. The start capacitor is bad; however, I am able to spin the shaft protruding from the rear of the motor upon switching the pump on. The...
Replace the start/run capacitor. What you are doing by hand is very dangerous.
Your booster, what shut it off in the past? Does this work through a independent relay that is powered by the pool pump circuit?
Talk to me ...
Thanks for your question today.
Jun 19, 2011 | Pentair 2 hp Challenger Pump
I have a challenger pool pump that has a very high pitch sound
The motor bearings are probably starting to fail. If you winterize the pool I would take the motor portion off the pump and have a local electric motor repair shop look at it. A simple bearing change and new pump seal would run $50 or less at most places. If not, shock the pool and run the pump overnight to balance the water and then pull the motor for the repair. It will probably only take a day or so for it to be completed.
Aug 30, 2009 | Pentair Challenger 1 1/2 Hp In Ground Pool...
My challenger 3/4 pump has started to sound louder and louder.
Replace the motor bearings before they fail completely and ruin the motor.
Jun 07, 2009 | Pentair Challenger 3/4 Hp In Ground Pool...
Disassemble pentair challenger pool pump
remove the 3 screws on the front with 1/4 inch nut driver remove the diffuser and mounting plate remove cap covering the bolt head on the back of the motor hold the motor shaft with an ajustable wrench or vicegrips turn the impeller counter clockwise it should only be hand tight unscrew the impeller
Apr 16, 2009 | Pentair Challenger High Head 1.5 Hp Pump...
Pentair Challenger High Head 1.5 Hp Pump Up Rated Logo
121 people viewed this question
Top Pentair Garden Experts
Dennis Key
Dennis Key
john h
Are you a Pentair Garden Expert? Answer questions, earn points and help others
