Question about IBM ThinkPad X40 Notebook
Output from my thinkpad x40 is balanced (left-right) through the built-in speakers, but only the left channel can be heard when external speakers are plugged in.
    Sergeant:
  • 238 Answers
As you said your internal speakers are OK, then may be the problem with the external speaker. Check with another set of external speaker. if works fine then check your previous external speakers connection. if still no sound the neeed to check the motherboard.
Posted on Aug 21, 2010
Why is my right channel not working on my Technics reciever?
The right channel output section or speaker might have damaged. Seek tech support.
Jun 03, 2012 | Audio Players & Recorders
I don't know how to use behringer feedback destroyer DSP1124p
Determine where in the mixer's signal path to connect the unit. Your options are:
1. One or two individual microphone channels via the mixer's CHANNEL INSERT in/out jacks.
2. The monitor mix output via the mixer's MONITOR OUT jacks.
3. The main mix output via the mixer's MAIN OUT jacks.
  • 2 Connect a balanced cable with the appropriate connectors from CHANNEL INSERT OUT jacks on the desired mixer channel to INPUT RIGHT or LEFT on the Feedback Destroyer's back panel for individual microphone channels. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to that mixer channel's CHANNEL INSERT IN jack.
  • 3 Connect a balanced cable with the appropriate connectors from the mixer's MONITOR OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the monitor signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the monitor amplifier INPUT jack or amplified monitor speaker INPUT jacks.
  • 4 Connect a balanced cable with the appropriate connectors from the mixer's MAIN OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the main mix (FOH) signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the main amplifier INPUT jack or amplified house speaker INPUT jacks.
  • Oct 17, 2011 | Behringer Audio Players & Recorders
    How do you balance sound between two speakers. Where is the balance control? JVC RX5000v
    On the front panel ONLY:
    1. Press ADJUST so that the MULTI
    CURSOR up/down buttons work for
    adjusting the sound.
    2. Press MULTI CURSOR up/down
    repeatedly until "BALANCE"
    appears on the display.
    3. Press MULTI CURSOR left/right to
    adjust the balance.
    • Pressing left decreases the right channel
    output.
    • Pressing right decreases the left channel
    output.
    please rate my solution.
    Jul 04, 2011 | JVC RX-5000V 5.1 Channels Receiver
    I want to hook up my CD-BA2100 to my Inspiron 6000 laptop but i don't know how to hook it up or what to use.
    The SHARP CD-BA2100 is a "stand-alone" cassette/CD/AM/FM player.
    Its manual states that it can accept left/right stereo audio output, such as from your laptop, if you purchase the correct adapter cable (from "line-out" or "head-phones-out" on your laptop):
    Video/Auxiliary (Audio signal) input
    To listen to or record signals from external sources through this unit:
    1 Use a separately available RCA cord to connect the desired external unit to the VIDEO/AUX jacks. (red ® right channel, white ® left channel) * When using video equipment (Laser Disc player or VCR), be sure to connect the audio output to this unit, and the video output to a television.
    2 Press the ON/STAND-BY button to turn the power on.
    3 Press the VIDEO/AUX button.
    4 Operate the external unit.
    5 To record the sound from the external unit ...
    i.e., you can use it as the speakers for your laptop, instead of the laptop's tiny, built-in, speakers.
    Mar 31, 2011 | Computers & Internet
    Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
    If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
    Jan 10, 2011 | Sony STR-GX800ES Receiver
    Channels out of balance - remote will only change left channel.
    switch input cables and try this will confirm if the amp has a problem or the input signal
    Jun 19, 2010 | Krell KAV400Xi Amplifier
    No Right Front Speaker Output
    Swap speakers over...check the balance isn't fully to the other channel...swap left/right phono cables over (if thats how your using it) other than that i would say is broke.
    Easy way to check speaker cable/speaker... touch a small battery (like used in a remote) across speaker wires, you will hear and see the speaker cone move.
    Aug 07, 2009 | Audio Players & Recorders
    Channel Problem
    It could be a bad balance control potentiometer or just broken/cold soldering joints due to the age. Bring it in a repair shop. Thanks. ebcelectronics
    Apr 06, 2009 | Audio Players & Recorders
    IBM ThinkPad X40 Notebook Logo
    104 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
