Question about Insignia 32" 720p Flat-Panel LCD HDTV
I have a Insignia 32 inch LCD TV Model number NS-LCD32. It recently started displaying no inputs. The backlight comes on but no inputs/ no sound. Green lines display if you press the menu,input, channel and volume buttons. The green lines are only displayed were the menu,input,channel or volume display would normally be on the screen. I took apart the TV and found two 470uF 35V capacitors on the main board to be bad. I replaced them with no luck. I also cleaned and reseated some connections to the TV. Same problem was there after turning the TV back on. Any ideas about anything else that could be faulty? Thanks
  • 2,318 Answers
The first troubleshooting step would be to measure all the voltages from the power supply to the other circuits boards specially the 5 volts going to the main board. If you have the following: Insignia 6HA0112010 Power Supply, check FU502 for open conditions.
If all the voltages appear normal, then the main board should be replace since is hard to find individual components for a component level repair.
Let me know if you need further assistance.
Posted on Aug 21, 2010
Where is the location of T CON board on NS LCD32
Cheryl, I will post links to what the T con board looks like so when you remove the rear panel from TV, you will be able to compare and find it easily.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
INSIGNIA NS LCD32 Con Board LC320W01 SLA1 6870C 0142B 2L
Amazon com INSIGNIA NS LCD32 CON BOARD CPT 320WF01C SD Electronics
Mar 23, 2016 | Insignia NS-LCD32 LCD TV
Insignia NS-LCD32
Most likely either the main board (processes all signal) or even an issue with the power board (supplies wrong voltage somewhere).
In either case not cheap.
Mar 23, 2012 | Insignia NS-LCD32 LCD TV
Purchased model NS-LCD32 second hand with no
Since you are getting the signal from the satellite, leave the satellite receiver ON and press input on the TV buttons until you get the signal back, wait 2 seconds after pressing the input button. Make sure the TV is on channel 3 if you are using the antenna input.
Jun 13, 2009 | Insignia IS-LCDTV32 32 in. Television
No Sound
if you have dvd player then connect its audio out to your tv audio in. if no sound then, it might be that your audio amplifier inside your tv is the culprit. usually this happens when turning the volume fully.
Jun 08, 2009 | Insignia IS-LCDTV32 32 in. Television
Red tint on my TV, instead of all colors? Reset doesnt work?
Sounds like the component cables are misplaced. Check that, and report back.
Dec 30, 2008 | Insignia IS-LCDTV32 32 in. Television
I have the following tv, Insignia 32" Flat-Panel LCD HDTV** (NS-LCD32-09CA) I get audio sound but no video output
Power supply board most likely, I have one just like it with the same problem in my shop right now.
Dec 26, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia 32" 720p Flat-Panel LCD HDTV Logo
645 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
