Question about HP LaserJet 1320 Printer
Hp laser 1320 manval tray paper not feeding proprly contynue
    Sergeant:
    Champion:
  • 387 Answers
You need to take ou the tray and look at the bottom you should see the feeder that pull the papaer make sure its not loss and try to clean the rubber wheen sometimes its dirty if not maybe the clutch is broken
i hope it will help
Posted on Aug 21, 2010
Paper Feed problem
I think its logic board related problem.
have a technician look onto it...
Nov 08, 2013 | HP LaserJet 1320 Printer
When i trunn on and when i want print all ways stuck
if you see brown marks on the center top of your page then its your feed roller... hp feed rollers come out easy... Get some rubbing alcohol or hand sanitizer solution and clean with a paper towel... Make sure to dry your feed rollers then put them back in... that should clear up your issue... if that still does not work you may need to replace feed rollers
HP LASERJET 1320 FEED ROLLERS TRAY 2
If it feeds ok but gets stuck at the back then chances are your fuser is bad. The belt is most likely ripped.
HP LASERJET 1320 FUSER ASSEMBLY
Sep 12, 2012 | HPLASERJET1320N LASER Printer INTEGRATED...
Paper jam in hp laser 1320
Unplug the power cord and open the cover and remove toner and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
Feb 10, 2010 | HP LaserJet 1320 Printer
Hp laserjet 1320 paper jams constantly. not even one page prints. what could be the problem?
could actually be the paper your using. make sure your using at the very least multipurpose paper or laser paper. check to make sure your settings for paper is also set to regular paper and not cardstock or special paper or anything else
Jul 30, 2009 | HP LaserJet 1320 Printer
Problem feeding paper in JaserJet 1320
Remove toner and cassette.
Turn the machine upside down .
The feed roller should not freewheel, one of the tabs could be broken off of the feed roller.
Feb 05, 2009 | HP LaserJet 1320 Printer
Load Noises
If the HP LaserJet series printer is experiencing a grinding or odd noise when printing or on power-up, open the printer and remove the print cartridge. Close the printer door.
If the noise does not recur with the print cartridge removed, replace the print cartridge.
If the noise persists, this may indicate a hardware failure. If possible, isolate and identify the location of the noise and contact a local HP sales and service ofice at the number noted in the product User's Guide . A list of phone numbers can be found at
http://www.hp.com/support .
Feb 15, 2008 | HP LaserJet 1320 Printer
Only the orange light is on
the feeding tray having foreign materials sruck the paper loading
Jan 04, 2008 | HP Laser Jet 1320 Printer
Laserjet 1320 will not pick paper
Paper misfeeds and failure to pickup the paper are both common symptoms of a worn pickup roller. This roller is on the bottom of the printer as shown in the attached picture.
With use the rubber tire gets smooth and can't grip the paper enough to pick it up and push it into the printer. The roller kit is easy to install yourself and will get the printer back going as good as new. You can get the roller kit here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
I hope this helps, if so please rate my solution.
BuddyMc
Dec 05, 2007 | HP LaserJet 1320 Printer
Paper jams
check the feed roll
Oct 05, 2007 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
111 people viewed this question
Seeker5211
Seeker5211
