Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Is there a master reset button for a keypad on a liftmaster garage door opener? my husband just changed something, inadvertently hit the Learn button, shut the garage door, and now he can't open it. this is a stand-alone garage with no other access points. thanks.
    President:
  • 3,197 Answers
There is no reset button. Usually a hole is drilled through the door so the release rope can be pulled.
Posted on Aug 23, 2010
I need a remote keypad for 41a5021-1e lift master. What model will work for this unit
check the liftmaster web-site. also any garage door sites may have parts offerings. google the part number as well.
Nov 05, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
Lift-master 1265 Garage Door opener clicks but nothing happens
CHECK ON THE OPENER FOR A RESET BUTTON, IT MAY HAVE JUST POPPED.
Apr 10, 2013 | Sears Craftsman LiftMaster Chamberlain...
Can the code bechanged on a Liftmaster Formula1 opener, just divorced and husband isn't nice
I have to assume a couple things here. First - I assume he still has a remote. Second - You want to change the opener so that his remote will not work and not just the keypad outside the garage. So.
To change the opener so that none of the existing remotes and the keypad will work just locate the smart/learn button on the rear of the motor unit near where all those white wires go. You may have to remove a light lens to get to it. Press and hold this button for 6 seconds. That erases the memory. Now you need to program your remotes. Hold the button down on the remote and then press and immediately release the smart/learn button. Do this for each remote you have.
Now the keypad. Press and immediately release the smart/learn button. Walk over to the keypad and key in any 4 digit code you want and press enter.
That's it.
May 17, 2012 | Sears Craftsman LiftMaster Chamberlain...
Will no longer open garage with combination as entered by installer. Daughter may have inadvertently reset code when she plugged in wrong sequence.
I doubt your daughter did something to it but you can try programming it. If it doesn't work after programming then it will need to be replaced.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Feb 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
Trying to reset code for a Garage Master Security + garage door opener - with no luck -
If you are trying to reset the code for the keypad, locate the smart/learn button on the rear of the motor unit. Press and immediately release this button and then walk over to the keypad and key in any 4 digit code you like and press enter.
If you are trying to reset the code for the hand remotes, you can't.
May 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
HOW RESET CODE FOR 940CB/67LM CHAMBERLAIN OPENER,
The learn button is the first button to the right of the LED.
May 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do I reset my chamberlain garage key pad, after the liftmaster repair guy erased the code? What do I push on the keypad, while holding the green liftmaster learn button? thanks
hope you have not held green button or your renotes will bew erased. Push green button for one second. Go to keypad. Enter 4 digit code and hit ENTER. Bulb on motor should blink. That's it.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wireless Keypad wont allow use of other door openers
hit learn button for 10 seconds. now nothing will work except wired buttons. Hit learn for 1 second and put in yur 4 digit keypad code and hit enter, light on motor will blink twice. hit learn again for 1 second and push button on remote. again bulb will blink. continue pushing learn for 1 second and adding another remote.
Dec 26, 2008 | Sears Craftsman LiftMaster Chamberlain...
Clearing codes on liftmaster garage door opener with yellow learn button
you seem to be doing right thing, hold learn button for 10 seconds, this should clear out all coded items; keypads, remotes.
Oct 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
364 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
