Question about Whirlpool DU1055XTSQ Built-in Dishwasher
I have a model du1055xtsq2 Whirlpool dishwasher. When running, it leaks at the bottom of the door opening. This was recently installed by myself,Is this a door adjustment or is there a float that may be malfuntioning?
  • Whirlpool Master
  • 43,501 Answers
Check the float
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Sep 29, 2010
Whirlpool dishwasher door falls open fast when opening. plastic part came off, but don't know where it is from
remove the bottom access covers on the bottom of dishwasher. turn on the dishwasher with water valve in off position so you can here the motor running,while its on, find the breaker and turn off power.you will here motor stop. disconnect power wires from power box on right hand side,then disconnect water line open the dishwasher door and at the top remove screws holding dishwasher in place. pull dishwasher out from bottom.you may have to adjust bottom adjustable screw legs. pull it out and check sides where springs are for the door to open and close. it may have came loose.
Feb 27, 2013 | Whirlpool Gold GU2275XTV Builtin...
After dishwasher fills an shuts off I get water coming out at the bottom of the door on both sides. I think it could be coming at the side ofthe door and at the top. I installed in Feb. of 2010. Could it...
The door seal could be the problem but if it leaks at the top also, I would check the latch and make sure that it is drawing the door tight against the rubber seal. Normally, if you run your finger over the seal you can find any defects in it.
Jul 27, 2011 | Whirlpool Dishwashers
I have a whirlpool quiet partner i dishwasher (model DU1055XTSQ2) that has suddenly stopped working. Control panel has partial functionality. All of the buttons on the control panel have a green LED...
The control board has failed.
CLICK HERE to see the parts breakdown.
CLICK HERE to see/order the part
Open the door & remove the 8 or so allen screws. The board is simply plug and play.
Bad design - the vent is right by the board - so its subjected to moisture.
Thanks!
Nov 14, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
Dishwasher leaks from the bottome of the door
if it leaked everytime then it would be your door gasket.but not everytime it's your door latch not engaging completely everytime.open the door and look and see if you can access the tightening screw for the door latch.probably not but look anyway.if you can then tighten the latch.
Nov 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Leaky Dishwasher
The dishwasher was installed with a defective fill valve or the valve was damaged during installation of the dishwasher.
Jun 23, 2017 | Magic Chef 24 in. DC4000 Free-standing...
Whirlpool quiet partner 1 # DU1055XTSQ2
Read this article, it should address your problem.
http://fixitnow.com/wp/2006/03/20/whirlpool-built-dishwasher-includes-kitchenaid-and-some-kenmores-wont-start-clean-led-blinks-seven-times/
http://tclaundryrepair.com/
Feb 24, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool DU1100XTPS dishwasher leaking from front door panel
Hi karen_kinzer,
I'm Harvey the Master Plumber.
The d/w was a recent purchase?
Then my advise to you is don't worry about it! The unit should be under warranty. It's time to make the call. Let the warranty repairman worry about it. If he can't fix it, he has the authority to condemn it and you'll get a new one. Anyway, this is one problem you should not have to worry about.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Dishwashers
Whirlpool DU1055XTSQ Built-in Dishwasher Logo
220 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
