Question about Maytag MSD2656G Side by Side Refrigerator
Lock light on maytag rerigerator will not go off and will not dispense ice. How do you unlock it?
  • 45 Answers
Hold lock button down for 3 to 5 seconds
Posted on May 16, 2008
How to change the light bulb in the outside ice/water dispenser
Question about Maytag 22.6 cu. ft. Side-By-Side Refrigerator with PuriClean II Ice and Water
The light on the outside door (where the ice/water dispenser is) won't turn off. It is dimmer than when you hit the 'light' button, but it stays on constantly when the door is shut. The 'light' button works and turns the bulb brighter, but when you turn it off, it just dims and doesn't go out. The light shuts off when the door is open and turns back on when its closed. Model Number MSD2456GEB
Posted by linsdesk on Aug 31, 2011
Aparajita Batabyal
  • 3,513 Answers
Re: The light on the outside door (where the ice/water...
Hi
Reprogramming your refrigerator to only light up when the dispenser is in use saves energy and keepsyour house darker at night. The light is controlled using the buttons above the water dispenser mechanism.Press and hold the "Lock" or "Lock Controls" button for three seconds to activate the controls if they currently are locked.Tap the "Light" button to switch off the light.Press and hold the "Lock" button for another three seconds to lock the controls from further changes. The light now only comes on when the dispenser is active.
If the above procedure won't work then this will be the cause of a faulty switch. This light switch is an integrated part of the dispenser control circuit board. This will require you, or your service tech to replace the entire dispenser/ice maker control board. It will be located just behind the dispenser fascia, mounted on a bracket. the actual light switch circuit is mounted on this board.
Try this procedure:-
Shutdown the unit for five minutes. Simply unplug the unit for this length of time. This will reset the board, and possibly, fix this fault if it is not to severe. If the shutdown dose not correct the switch action, simply replace the dispenser/switch control circuit board.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Jul 25, 2015 | Maytag Refrigerators
Need to replace Whirlpool 2322580
El motor que hace salir el hielo esta trancado Modelo N? 2322580; necesito comprar uno nuevo; favor informar
Apr 09, 2012 | Whirlpool Refrigerators
How to unlock ice and water dispencer.
Press and hold the lock button (one that has key emblem) until the lock light goes out. If that does not solve it or that light is not on , you may have a dispenser board problem..
Jun 11, 2010 | Maytag MZD2766GES Side by Side...
Unlock water and ice machine
OK from what I understand for some reason ice and water appears to be locked. This information is in the service manual for your model but also results in test that you will need to do there at the dispenser control. It will be listed on page 108 of manual and section 2-8 of the manual. I will assist you if you like, Sea Breeze
Mar 24, 2010 | Maytag MSD2756G Side by Side Refrigerator
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Can't unlock ice water depenser on maytag side by side
On most brands all you have to do is hold the lock button until it unlocks.
Jun 10, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice dispenser lever will not return to off
hi thre,
it was already defective,have replace on it., pull it out,and have it for sample you can buy this on rerigeration and aircondioning supply.where near your place.or have it do by your service technician.have a nice day,don't forget to rate me,thank's a lot
May 02, 2009 | Frigidaire FRS26H5AS Side by Side...
Maytag Freezer Door Panel Locked
replace the front board but read your manual first because some lock without it saying it has the lock feature by hitting 2 buttons for 3 sec at the sametime locks and unl;ocksit
Mar 18, 2009 | Refrigerators
Can't unlock my ice dispenser
press the lock button three times in a row
Feb 10, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag lock and filter change
to reset the change filter light:
Press hold the LIGHT and LOCK pads until the CHANGE FILTER light blinks (approx. 3 sec.)
Dispenser lock:
to interrupt power to the water and ice dispenser so it cannot be used , press the lock pad 3 times within 10 seconds.
Jan 21, 2008 | Maytag MSD2454G Side by Side Refrigerator
Maytag MSD2656G Side by Side Refrigerator Logo
56 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
