Question about Kenmore Microwave Ovens
Kenmore Microwave: model # 565.66401690 It is showing an L on the window where the time is. It doesn't heat. How can i change the power level?
  • Kenmore Master
  • 9,098 Answers
The child lock may be on.
The first thing I would suggest is a hard reset.
Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If you still need, help, I'd check the owner's manual.
If for some reason you don't have yours, you should be able to get it
from the Sears parts site.
Just enter your model number there.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
On the resulting page, look to the right for the blue "View manuals" button. Click there.
Kenmore Microwave: model # 565.66401690  It is - view_manuals_button.jpgview_manuals_butKenmore Microwave: model # 565.66401690  It is - view_manuals_button.jpg><img src=ba1cbef.jpg
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
For repair service on Kenmore appliances, see Sears Service.
Posted on Aug 23, 2010
bestdarngood
  • 3037 Answers
SOURCE: yesterday microwave worked fine today it doesnt
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on Apr 26, 2009
SOURCE: wjusino just asked: My kenmore microwave doesnt heat.
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Posted on Jan 26, 2010
heatman101
  • 43501 Answers
SOURCE: My Kenmore microwave model 565 60502990 will heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jhhjujk
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: microwave turntable not turning, not
heatman101 ,./';';
Posted on Aug 13, 2011
caroldon
  • 17130 Answers
SOURCE: Ge microwave says may not change power level at
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides.Since in this case the power level cannot be changed it seems the pads are faulty or the processor has hung up. If so the controller board is a suspect.
If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
Posted on Sep 06, 2011
Power level change
You may have to enter a value with the number keys.
A 5 might give you 50% power or you might have to enter 50.
It all depends on the manufacturer's program. I'm not familiar with this model.
Feb 06, 2014 | Kenmore 62109 Microwave Oven
Microwave oven is not heating food power level can;t be changed at this time
That shows triac semiconductor is working fine, the problem is the magnetron, "heats food" cracked high voltage diode or a shorted high voltage capacitor.
Mar 21, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Nov 22, 2011 | Microwave Ovens
Reduce heat
Normally it's one of these two sequences to cook at 1 minute at 60% power:
Time Cook, 1, 0, 0, Power Level, 6, Start
or
You can download many Kenmore owner's manuals free.
Enter your full model number at the Sears parts site.
Many times, the owner's manual will also have the installation instructions inside.
Sears parts site.
May 04, 2010 | Kenmore 63792 Microwave Oven
Kenmore microwave Model 72 8975590 (750 W) is taking longer to heat food. Takes 3.5 min to bring one cup water to boil, previously took 2,5 to 3 min. Does the element lose power over time?
I can adjust the power level so that circuitry seems to be ok. The longer water boil time could be partially due to the colder winter temperature of the inlet water. We'll just cook the food a bit longer as long as the magnetron is still working.
Jan 21, 2010 | Kenmore Microwave Ovens
Kenmore Microwave Oven model #401.80082700
Sounds like a bearing is tightening up when it get heated up with use. Then after a cool down period it works normally until using it heats it up again. Eric
Sep 15, 2009 | Kenmore 62622 Microwave Oven
Yesterday microwave worked fine today it doesnt heat anything and power level does not show up on the led screen kenmore model 721
Benjamin
Apr 25, 2009 | Kenmore Microwave Ovens
Kenmore Elite taking long time to heat items
This is most likely a failing magnetron.
If it's less than 5 years old, Sears/Kenmore should cover the part, but you would still have to pay for a service call.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 16, 2008 | Microwave Ovens
Microwave heats but slowly.
This is the second time I have requested assitance on this site with no response. The beginning of this thread dates back two months. Why would I ever want to pay for support when it is so poor at this level?
Jan 06, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
330 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
