Question about JVC AV-27220 TV
My TV will not change channels it seems stuck on channel 2 This is true with the remote and with the buttons on the set.
  • 132 Answers
Try to change the channel by manually putting the numbers in with your remote. If this works then you probably need to program your channels.
Posted on Aug 21, 2010
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
What buttons do i press to add/delete channels on emerson tv model# EWC1304? I cannot seem to get pass channel 2. I have no remote.
I have the same problem, my tv will not allow me to change channels but will only let me add/delete the channel the tv is currently on
Oct 11, 2011 | Emerson EWC1304 13 in. TV/VCR Combo
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
Channels keep flipping
1. check the channel switches on the tv panel if they are stuck
2. take out the batteries of your remote and see if the channels still change, if it stops, then the remote needs replacement or cleaning
3. if none of the above are true, your tv needs repair
hope the above abswers your question
thank you for visitng fixya.com
Jul 06, 2011 | Insignia LCDTV26 26 in. Television
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
Channel keeps changing on its own
things to try:
1 look for a remote stuck in a couch(or other near place) that is barely peaking out enough to change the channel.
2. Check that the channel up or down button is not stuck on the tv and or any remote that is set up for it.
3. Find the tv's infrared sensor and cover it with your hand or tape. If the channel changing stops then something is emitting infrared that is causing it to channel hop (occasionally security systems can cause this to happen) also some kids toys. Anything that emits infrared light basically.
once you have found the source (neighbor with the same brand tv for example) or a remote with the cushion pressing the button for you. then you will should be good.
Sep 14, 2009 | Astar LTV-2701 27 in. HD-Ready LCD...
TV stuck on one channel
Remove batteries from remote, and test again the touch buttons on TV with remote batteries out. This to exclude the possibility that remote has a stuck button.
If the problem persists , then it is probably a faulty IR board on TV (the one that gets IR signal from remote), or a faulty touch button switch.
May 16, 2009 | iLO 3200 32 in. LCD Television
VCR channel stuck on channel 2.
It won't play on the usual channel 2 or 3. Press 00 on your remote for the vcr.
Mar 14, 2009 | Televison & Video
I am stuck on channel 2
some tv's default to channel 2 after being unplugged.since it is a older tv ,the buttons on the remote and the tv maybe worn down.on the tv itself try pushing the buttons down a liitle harder. if you have aux or line in/video inputs,scroll down on the channel button to log into a aux channel for the dvd player.as for the remote try buying a cheap universal remote to see if that works.
good luck
wg
Feb 02, 2008 | Zenith A25A23W 25" TV
JVC AV-27220 TV Logo
401 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
