Question about Sony KP-46WT510 46" Rear Projection HDTV
Picture is out of alignment kind of 3 dimentional
  • Sony Master
  • 8,617 Answers
Thats a convergence Failure. You can get the Sony type 1 convergence repair kit which works for your model at www.tvrepairworld.com the kit contains the parts and the CD with instructions.
Posted on Aug 21, 2010
The picture jumps and the I can't align the white boxes
open very carefully the back , you will see two big chip beginning with the letter STK . if you know how to solder , remove them and put the news ones. when replacing chip like that you replace by the same kind of chip
Mar 11, 2012 | Televison & Video
When I print pictures I have lines every inch on the picture. How do I correct this?
That is almost always print head alignment or dirty ink jets. Run the cleaning and alignment utility that is in the printer software. If that doesn't work make sure when you print pictures you change the print settings to the right kind of paper (photo) and the right print setting (photo)
Jan 27, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My picture is blurry and discolored.
THAT KIND OF TECHNOLOGY IS PRONE TO WHAT ARE CALLED CONVERGENCE FAILURES. PROBABLY THE MOST COMMON FAILURE HAS TO DO WITH THE CIRCUIT THAT KEEPS THE 3 PICTURES FROM EACH OF THE PICTURE TUBES ALIGNED TOGETHER.
Dec 17, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Am not aware of aligning my screen on my HTC touch 3G T3232 mobile kindly assist
1. Download the latest activesync and connect your mda to your computer and verify your device is connected(not as guest)
2. Perform a soft/hard reset on your MDA then tap your screen to start the screen alignment wizard
3. Download the remote screen alignment tool attached and install it on your machine.
Oct 08, 2010 | HTC Touch HD Smartphone
My picture is messed up. Its kind of unclear with
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 04, 2010 | Hitachi 50GX30B 50". Rear Projection...
I need Dogbone bearing dimentions
The outside edge of all bearings have a maker and bearing number i.e. "NGK2604". Get the number then go to an industrial bearings company. They can look up the bearing and see if it is in stock and if not, they can look up a matching bearing from a different manufacturer i.e. " SAS3107". The actual dimensions will likely be available at the same location. By the way, most people have no idea what you mean by "dogbone". Do you mean the crankshaft main bearings?
Jun 08, 2009 | 1997 Honda CBR 600 F(3)V
We have a marrige ceremonyhallthehall dimentions are as below, toll carpet area=45'(feet)X82'(feet)=3690 height=10'(feet) glass area=5'(feet)X 45'feet=225 kindly provide the exact tonage required . re
what is the light wattage using in the hall the seating capacity,orientation,any other eletrical equipment,spot light,oops so may details missing???
May 31, 2009 | Coleman Mach III Air Conditioner
Blurry picture
you can try to clean the mirror and lenses. or try to adjust the focus for each CRT(picture tube). also could be a convergence alignment issue. check the main menu for convergence alignment feature.
Apr 07, 2008 | RCA P46924 46" Rear Projection Television
Lost picture
sounds like video card failure mode, 101..you a technically adroit person?
Apr 03, 2008 | Televison & Video
Sony KP-46WT510 46" Rear Projection HDTV Logo
51 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
