Question about Slant Fin KZ-12 Air Cooler Fan
Does the slide-out "filter" need to be ever changed and if so, can it be ordered?
How to change the fuel filter
Remove the right and left sidecovers, turn the petcock off - left upper side now accessable where the side cover removed. Remove the fuel filter phillips head screw from lower right side and slide it out. removed hose clamps from old one and withdraw filter. Replace in reverse order. Further info can be obtained from email group via www.suzukicavalcade.com
May 23, 2010 | 1986 Suzuki GV 1400 Cavalcade LX
How do i change cabin airfilters
there is a access door in the back of the glove box. Open the access door, and you can remove the filters. there is 2 filters, pull the first one out, slide the 2nd filter to the right and remove. put new filters in in reverse order,
Mar 09, 2010 | 2000 Chevrolet Venture
Where is the fuel filter on my 1999 chevy silverado 5.3
Hello, your fuel filter is mounted inside of the frame almost directly under the driver's seat. I recommend changing it every 10,000 miles. This is more frequent than the manual, but I believe it keeps the fuel system more efficient.
Mar 07, 2010 | 1999 Chevrolet Silverado 1500
How do I change out the air filter for the 2200 model? Not sure where to open it up in order to check the air filter and if needed change it out. Thank you.
After you pull out the filter case. There is a tab on the bottom and on the top that holds the ends in undo these.lift out the combs and the filter. Open the new filter and hook it onto the tabs of the filter case and close the ends back up. Get one of the combs in all the cracks of the new filter then slide the next comb in right next to the one that is installed and slide it down to the furthest slot where the combs go. and do this for the rest of the combs until they are all inserted. once they are all in replace the filter case into the cavity be sure to line the slots up on the case and the cabinet and put the door back on.
Jan 03, 2010 | Aprilaire 2200 Air Purifier
Where is the location of the cabin air filter for a 2002 Cadilac Deville DTS
It'll be located under your hood underneath the plastic shroud at the base of your window. You'll need to remove a couple of the retaining clips in order to lift the shroud up in order to access the filter. All you need to do is pull the old filter out once you have enough room and slide the new on in
Oct 20, 2009 | 2002 Cadillac Deville
How do i change the cabin filter in my acura 2009 tl?
The advise by Techbuster was a bit off. The '09 is a bit different than the earlier models. To change the filter, pull the center divider in the glove box straight forward. The cabin filter housing in immediately behind it. Push the two clips on the outer edges inward and slide the tray out. Replace the filter, reinsert the tray, replace the center divider.
Sep 16, 2009 | 2009 Acura TL
Need someone to explain in detail how to change the water filter ....i have a replacement just don't know how to do it
At the bottom on the kickplate ( by the picture on this thread , you didn't give a model number ) twist the slot under freezer door , to the left and slide out filter . The filter slides off the holder . Slide new filter on and reinstall into the hole , twisting the holder clockwise so it seats .
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Audi tt 3.2 quattro oil filter change
The insert or cartridge filters are easy to change..You must jack up the front of the car, remove the engine belly pan. in the front of the motor there is a black cylindrical housing for the oil filter cartridge..On the bottom is a cap that just screws off..Unscrew the cap, take it off, slide the old insert off, then slide the new one on..Screw the cap back on and voila! you are finished..If the insert came with a new rubber o-ring, make sure to replace the old one on the cap.
Jun 22, 2009 | 2005 Audi TT
1992 BMW 535i - Ventilation Problem
It could possibly be the cabin air filter is clogged, especially if it has never been changed. Aside from that it is probably one of the stepper motors that adjust the various vent gates in the air passages under the dash. Although replacing the cabin air filter on this car is fairly easy, comparatively speaking, you do have to remove the glove box in order to do it.
Mar 27, 2009 | 1992 BMW 5 Series
Wrong Grease Filter for Sharp R-1870 Microwave
I also have a Sharp over the Range Microwave oven that requires a charcoal filter. But my diagram shows that the charcoal filter goes behind the slotted panel at the top of the microwave. To reach the filter, you must remove a screw on the top edge of the microwave. This allows the panel to come off. Your charcoal filter goes there. Since your oven is new, you do not need to change this filter yet because it's not dirty. I would save it for future use.
According to my book, there are two kinds of filters with this oven. The charcoal filter is the one behind the front panel. The Grease filters ARE the two metal mesh ones. They can be cleaned with hot soapy water, or I put mine in the dishwasher.
Mar 14, 2009 | Sharp R-1480 Microwave Oven
Slant Fin KZ-12 Air Cooler Fan Logo
32 people viewed this question
Top Slant Fin Dryers Experts
Are you a Slant Fin Dryer Expert? Answer questions, earn points and help others
