Question about LG LH-C6235 System
Hii my name is parminder sagar we have a durabrand dvd player .is this just on 5 . 20 min work and than shut dawon power automaticly . give me slution
My remote does not work ( model #1002) what is the code for it or can I buy a replacement?
You can try one of Universal Remote Controls for around $10. which covers all DVD players, TV... brand names (of course your Durabrand included).
I found Durabrand's code on my universal remote (3 of them) here, the top one being the most popular:
21023
21127
22164
Good luck
Mar 01, 2011 | Durabrand DVD-1002 DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Replacement ad/dc power cord
you can get a replacement ac/dc power cord for durabrand portable dvd player model # PVD-707 here;
http://www.acdapter.com/DURABRAND_PVD_AC_ADAPTER.html
Dec 11, 2008 | Durabrand PDV-705 Portable DVD Player
Lost remote!
yeah i agree it's bull sh*t
Nov 23, 2008 | Durabrand DVD-1002 DVD Player
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Need DC power cord, new battery and car adaptor
If anyone would know it would be the company who made it. Walmart buys from small electronics companies and puts it under the Durabrand name. Very Sneaky. The company that makes the DVD player is called Lenoxx. There website is www.lenoxx.com. Here is the rest of their contact info.
Customer Service
Evergo Corp.
35 Brunswick Ave. Edison, NJ 08817
Tel :
(800) 315-5885
Hours: Mon-Thurs 8:00 am - 5:00 pm EST
Fridays 8:00 am - 1:45 pm EST
Customer Service Email: Evergo@att.net
Apr 07, 2008 | Durabrand PDV-705 Portable DVD Player
Where can I get these for DVD model PDV 705
Customer Service
Evergo Corp.
Tel :
(800) 315-5885
Play Button not working.
Customer Service
Evergo Corp.
Tel :
(800) 315-5885
Apr 04, 2008 | Durabrand PDV-705 Portable DVD Player
Power cord
Yes you can check in IT stores (Radio Shack, Best Buy etc) Sometimes it comes as universal adaptor. All you need is the match socket type Voltage and Amperage. There are available for car also. You can check the brand names Targus, Belkin and other trusted brands.
Good Luck
Jan 24, 2008 | Durabrand DUR-1500 Portable DVD Player
LG LH-C6235 System Logo
Top LG Audio Players & Recorders Experts
Electro Med Services...
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
