Question about Western Digital Passport 320GB External USB 2.0 Hard Drive
Hi, How to format external hard disk whose file system shows as RAW. Under my computer the drive is shown as Drive F but any attempt to open the drive gives an error to format the disk. While attempting to format, the windows xp gives an error that "The disk in drive F: cannot be formatted".
  • Shashi Bhushan Shukla Aug 22, 2010
    I think somehow, my problem of External Hard Disk have been misunderstood as XBOX problem !! Sorry.
  • 104 Answers
OK try this
USING DMZ When you enter into your router config window, you need to find the Tab DMZ, it should be under applications and gaming if you are using Linksys. Once you find the DMZ tab, click enable and type in the last digits of your XBOX into the box below. Yes when you do this you are opening all the ports on your Xbox, which is insecure, but show me someone that has hacked into an xbox 360?
<MAKE SURE YOU SAVE SETTINGS>
Using Port Fowarding After you have enabled DMZ, find the Port Fowarding tab, should be under advanced routing. For the name type in XBL or whatever you want, and for port range put 87 to 89, choose UDP, then your XBOX last digits, and enable. Then do 3073 to 3075 choose TCP, then your XBOX last digits, and enable. Then again do 3073 to 3075 choose UDP, then your XBOX last digits, and enable.
after done - then cold reboot both Router and Xbox
XBOX go to the system blade, choose network settings, then test connection. This may take a bit, but when it gets down to NAT type it should say OPEN.
Posted on Aug 21, 2010
My 1T external HDD won't format and reads as raw
I am assuming (because you did not tell me) that you are running a version of Windows. You need to open help and support and search under drive management. The drive is showing as raw because you have not yet created a basic volume or any partition structure.
Apr 02, 2015 | Computers & Internet
How to recover data from the raw hard disk
Hi
Don't use the drive at all until you are in a position to start a recovery scan.
To do this you need:
A working computer that you can attach this drive to as an extra.
Another drive (external or the boot drive) large enough to save any data
Appropriate software for the data recovery.
The software is the most difficult to specify as some are better at some recoveries than others. I have had some success with Pandora Recovery, available here:
http://www.freewarefiles.com/search.php?query=Pandora+recovery&B1.x=7&B1.y=11&boolean=exact
or PC Inspector File Recovery, available here:-
TechRadar
There are many Recovery programmes out there, you may find another you feel happier with, but both the above have worked for me.
Once you have downloaded and installed the software to your computer, read the help/instructions carefully before you start.
Basically there are three steps to recovery :
Firstly a full scan of the affected drive. Be patient this can and often does take hours, especially with larger drives.
Secondly the programme compiles a list of the files it can recover, often with an estimate of the probability of the file being intact and usable after recovery.
Thirdly identifying those files you want to recover and telling the programme where to save them once recovered - NOT the drive you are recovering from.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 05, 2014 | Hard Computers & Internet
How can I find the files on my 1tb, seagate external drive?
You maybe removed the driver for the hard drive when you ran the anti virus. Those programs can do some strange things. If you click on the start, then computer. It will show all hard drives on your system. If you cannot find your files. I would think your computer does not see the external hard drive. To reinstall the driver, you would need to go to the driver's manufactures web site to down load or yours may have came with a disk. If so just run the disk. Could do a system restore , but that would be last option .
Aug 02, 2014 | Seagate FreeAgent Pro 1TB External USB...
When I look in disk manager it shows my external hard drive is in raw
DO NOT FORMAT YOUR DISK. It has been damaged; how easy or even possible to recover your data depends on the degree of damage.
Try your HD in another computer; if it works, make a back-up of your files on another disk.
To understand what RAW format means, try this
http://www.ehow.com/facts_7167186_raw-disk-format_.html
or look for it in Wikipedia.
By searching the internet ("raw disk has data on it"), the first article I found was this
http://html5.litten.com/how-to-fix-external-disk-drive-suddenly-became-raw/
which may be of some help.
In that article a Linux system is used to read and modify the disk. There other tools for repairing this type of fault, for example, http://www.easeus.com/resource/recover-raw-disk.htm
(I do not know if this free:: the information in the article is certainly free though)
Recovering your files will probably mean a lot reading, research and time, but you might be lucky. I recommend reading any article you are going to use through to the end before you start with it.
25.April.2014
Mar 03, 2014 | Computers & Internet
After I format my hardisk for several times and the file system still showing RAW. how to make it ntfs.
Install the drive on a working computer and access through disc management. that will allow you to initialize the drive and format it ntfs. Goto my computer right click select manage select drive management. This works on XP if you have other OS than search for disc management for your OS.
Aug 29, 2013 | Seagate Computers & Internet
Seagate raw drive
Your data is already gone. The drive is raw. No partition no format.
here is a link to a free data recovery program, this probably wont work but may be worth a try
http://getdataback-data-recovery-for-ntfs.soft32.com/free-download/?lp=dsa&tg=us&kw=_cat%3Asoft32.com&mt=b&ad=35354358678&pl=&ds=s&gclid=CIa78aSmk74CFc5ffgod9gEAlA
just be sure to opt out of all garbage they want to infest your computer with.
Jun 05, 2013 | Seagate U6 (ST340810A) 40 GB Hard Drive
My Transcend v30 pendrive is not working i had checked it in other computers but it was not working
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 23, 2011 | Transcend (589307) Media
My pen drive is in RAW file system, I ca'nt open or format it.
Try to get a software called parted magic. its linux based and you should easily format the pen drive.
U can also try HP USB Disk Format Tool.
May 28, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
The file system of my hard drive become RAW.
http://www.z-a-recovery.com/unformat-tutorial.htm
This tutorial describes the procedure to recover one volume when
  • the volume was accidentally formatted
  • Windows reports the volume is "raw filesystem", or "not formatted"
  • An external drive failed, either flash (so called "thumb drive") or an hard disk connected using USB or FireWire enclosure.
  • MFT is corrupt on the NTFS volume, rendering filesystem partially or completely unreadable
The recovery is done in seven steps, requiring about eleven (11) mouse clicks. Note: The older than current versions of ZAR might have been used to create the screenshots in this tutorial. We did not update the screenshots if there is no significant difference between older and current versions. If you see some option in the program which is not described in the tutorial, just leave it at its default setting.
plashkablue_left.gif Step 1 - Get, install, and start ZAR
plashkablue_right.gif box-top-l.gif box-top-r.gif Download and install ZAR just like you do with any regular program.
When you run it, ZAR displays the window like the one below:
  1. Click "Next >>"
plashkablue_left.gif Step 2 - Select processing mode
  1. Select "Recover data from a simple volume or from a functional RAID volume"
  2. Click "Next >>"
plashkablue_left.gif Step 3 - Select physical device to recover
  1. Select the appropriate hard drive
  2. Click "Next >>" for a list of volumes (logical disks) on this hard drive
Nov 19, 2008 | Western Digital My Book Essential Edition...
Western Digital Passport 320GB External USB 2.0 Hard Drive Logo
166 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
