Question about Whirlpool Duet GHW9150P Front Load Washer
The washer won't drain or do anything the display reads the time in a cycle
  • 375 Answers
Remove the panel below the door, pinch off the hose from tub to pump (and drain hose too if you can, then remove the filter insert from the drain pump. To do that turn the handle on the drain pump counterclockwise and pull it out. Remove debris in the filter. Remove motor from the pump, and check for debris. If it's still not draining after that - put the washer in the drain cycle and verify the line voltage (110v) coming to the plug on the pump. Do not disconnect the plug from the pump while checking for the voltage. If 100v is present and still no drain - replace pump. If no voltage to pump, you may have a problem with door lock or control board.
Posted on Aug 21, 2010
Washer won't complete cycle. F02 flashing
F02 = long drain
try this
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filterfor foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Oct 23, 2012 | KitchenAid KHWV01RSS
Where do I find the MCU on my Kenmore h2plus washer?
  • 1 Check for any error codes in the Estimated Time Remaining display. The code "F20" indicates a water inlet problem. Press the Stop button twice to end the cycle and check that the faucets are turned on fully. Take a look at the inlet hoses. Close the valves and unscrew them. Look for any clogging on the screen and clear it.
  • 2 "F21" indicates a draining problem. Again, press the Stop button twice and take a look at the drain hose. Make sure it's not kinked, frozen or clogged.
  • 3 "SD" on the display indicates the machine has gone into its Suds Routine. The Suds Routine removes excess suds so that the garments rinse properly. It's not a problem, but can be an indication you've used a non-high-efficiency powder. Just let the SD routine complete and the draining will continue.
  • 4 Make sure the washer is level if it gets noisy or vibrates too much. Use the leveling feet to adjust the level. They screw and unscrew for adjustment. Make sure the shipping bolts were removed from the back of the machine if the machine gets too noisy. See the "Removing Transport System" section in the instruction manual.
  • 5 Check that you are using HE detergent if you spot leaks. Check that the fill hoses are tight and that the drain hose is secured to the drain pipe. Check that the drain isn't clogged.
  • 6 Make sure the load is balanced if the washer won't drain or spin--or if water remains in the washer. Redistribute the load.
  • Buy Custom Car parts.
    Jun 02, 2012 | Kenmore HE2 Plus Front Load Washer
    I had OB error code. Please help me how to fix it Thank you
    Hi there this is the Out of Balance Error code and can be a few things.
    If its happened just the once don't worry about it - probably just a heavy uneven load.
    If it happens again or repeatedly adjust the clothes in the drum and restart if it keeps happening then check that the unit is draining and that the drain hose is not clogged.
    If everything is draining and the washer does this when empty you are going to have to start replacing parts so probably best to get someone in to have a look.
    You can do a drain test yourself - Make sure there is water in the Washer then press (within 5 seconds so quite quickly)
    Set Delay Time End of Cycle Signal Set Delay Time End of Cycle Signal
    Display should read "dt"
    then Press Jeans/Colors so display reads "t4"
    Drain Test should commence
    May 04, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
    F21 is flashing,... what is this
    If the drain time exceeds 8 minutes the water valves turn off.
    NOTES:After 4 minutes the "Sd" error will be displayed, then
    4 minutes later the "F/21" error code will be displayed. Press
    F21 washer drain time exceeded
    Possible Causes/Procedure
    kinked.
    4. Check the drain pump filter for foreign objects.
    Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Washer displays Ld and won't drain. won't restart or anything. kenmore oasis
    The LD fault code indicates that the washer took longer than 5 minutes to pump out the water and reset the water level pressure switch. You should be able to press STOP/CANCEL to clear the display.
    Check you drain hose for kinks or clogs. You could have a clog or failure in the drain pump that is causing this problem.
    You can use a diagnostic test to start the drain pump. To start this diagnostic test, press the following keys in this order: SET DELAY TIME, END OF CYCLE SIGNAL, SET DELAY TIME, END OF CYCLE SIGNAL. The display should show "dt" after this key dance. Press the JEANS/COLORS key to start a 60 rpm spin and drain test that will terminate after 40 seconds. Listen for the drain pump. It should be running during this test. Also listen for unusual noises from the pump that could indicate that it is clogged. You may be able to drain the water from the washer using this diagnostic cycle depending on the severity of the clog or failure. If not, you may need to manually remove the water. If you are able to safely access and clear a clog in the drain pump or drain line, you may be able to repair this problem yourself.
    Jan 07, 2011 | Kenmore Washing Machines
    My maytag clothes washer Bravo quiet series 300, keeps flashing a Sd error code. Or it may be 5d
    What does the Sd code mean?
    This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
    Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
    Use only HE High Efficiency detergent for BravosTM washers.
    Is "Sd" displayed and the wash cycle dial is flashing?
    This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
    Is "Sd" displayed and the wash cycle dial is not flashing?
    If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
    Is the drain hose kinked or clogged?
    Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
    To remove the error display, press Power/Cancel or Pause/Cancel once.
    If Power/Cancel or Pause/Cancel does not work:
    1. Unplug the washer or disconnect the power for one minute.
    2. Plug in the washer or reconnect the power.
    3. Re-select the cycle and press Start/Pause.
    NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
    Dec 27, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
    Washer stopped draining
    normally in the bottom of the unit there will be a small pump/filter assembly you need to open it up and clean the pump/filter out..run a drain cycle 2-3 times before cleaning.....have some towels ready my HE4T had this problem and still gave a small flood
    May 25, 2009 | Washing Machines
    I have the Kenmore elite calypso washer and it stops and displays LD. What does this maean and how do i fix it? Thanks!
    “F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
    1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
    2.Check the drain hose to make sure it is not kinked or clogged.
    3.Check the electrical connections to the pump and ensure the pump is running.
    4.Remove the drain pump filter and check for foreign objects and/or debris.
    To check the drain pump, click on the following link for step-by-step instructions
    http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
    If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
    Jan 24, 2009 | Kenmore 2295x Top Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    74 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
