Question about Saws
I need to remove and replase the arbor housing from main base, any idea how to take the housing off?
  • 2 more comments
  • brad783 Aug 21, 2010
    this is a sears craftsman table saw. I got a new arbor housing but cannot remove the old one. Need help
    if it was that easy I would not have paid $18.00 for the advice. I don't think you know what I mean. There is no allen screw holding this piece in place.
    There is no allen screw for the housing. Do you understand what my problem is?
    I have an older craftsman 10" tabel saw (Model: 113.298031) and the part listed in the parts list that I am replacing is; part #52, 3509, Housing,Arbor. I cannot remove the broken part from the main assmebly (not sure how it is held in place). I need help in removing the broken part and replace it with the new part. If you need to see a diagram I can email it to you. Thanks.
  • 10,865 Answers
Hello Brad. Here is an excellent link that shows how to do this task in a common table saw. If you know what brand and model you have I can give you a more specific answer. http://lumberjocks.com/topics/10325
J.
Posted on Aug 22, 2010
  • 10,319 Answers
On most table saws a allen wrench is needed to remove the arbor
Posted on Aug 21, 2010
  • 2 more comments
  • frank thomas wilson
    frank thomas wilson Aug 22, 2010
    Also your may have a double nut holding it place. If the model and name was shown much better help can be presented to you
    The link below you will need to copy and paste it to a new browser window
    http://www.google.com/search?hl=en&q...
    Click onto the fourth link for complete illustrations of this saw and the ARBOR
    Copy and paste this link below to open this web page
    Upon retrieving this web page click onto the 4th line to pull up the Sears Owners Manual for this saw. It will have exploded photos of it showing the Arbor towards the very end of the manual
    The exploded views of this manual should help you very well
    Good luck
I bought an Ammco 4000 brake lathe and the arbor was not installed in it. The one they gave me has surface rust on it. It will not fit into the spindle either. I'm not sure on got the correct one. What is...
A standard arbor which you should have been provided with should look like this...
The standard arbor size is 1 inch.
A used arbor is okay--but if it has rust on it, you should remove the rust with a wire-wheel mounted on a bench grinder (and be sure to use eye protection because fast spinning wire-wheels routinely throw off wires).
Any arbor (especially new arbors) have to be lapped into the spindle using a fine lapping compound which can be easily found at auto parts stores.
Apply a small amount of lapping compound onto the mating surface of the arbor and insert it into the spindle with the machine turning. Hold the arbor tight and let the lapping compound grind away for about 40 seconds.
Remove the arbor and reapply another small amount of lapping compound--repeat the grinding process one more time. Remove the arbor and using a rag clean the lapping compound from the arbor.
Clean the lapping compound from the outer spindle seat. The outer seat is easily accessed--the inner seat of the spindle is harder to access. This is cleaned by doubling a rag over the threaded end of the arbor. Holding the rag, insert the threaded end into the spindle and clean the inner seat.
Turn off the machine and insert the arbor into the spindle. Insert the spindle "draw bar" (which you should also have) through the hole in the drum gear box (Infimatic gearbox) on the right hand side of the machine.
Holding the drive pulley, tighten the draw bar.
Next you have to check the arbor run-out using a magnetically mounted dial indicator as shown....
Mount the dial indicator on the machine's twin cutter (tightened down) and crank in the disc-feed carriage until the dial indicator can make contact with the arbor.
Start the machine. The arbor run-out should be no more than 1 1/2 thousandths. If the run-out exceeds greater than 8 thousandths it cannot be straightened. Arbor with slight run-out problems can be straightened.
(Note: If the dial indicator vibrates too much to get a reading--you will have to manually turn the machine using a wrench as described below).
First try loosening the draw bar, and rotating the arbor 180 degrees and then re-tightening the draw-bar. Many time this will solve the problem or at the very least lessen the run-out or bring it within spec.
If the arbor is still exceeds spec, then you have to straighten it. To straighten an arbor, manually turn the machine with the "Ammco wrench" (which you should also have) using the nut on the draw bar. Turn the machine until you find the high spot (straight up), then remove the dial indicator to prevent damage.
Using a copper dead blow hammer, give the arbor a modest whack, and then recheck the run-out. Repeat the process until you manage to get the arbor within spec.
Please note that straightening an arbor using this method will sometimes break the arbor off. You are rolling the dice when straightening an arbor--but this is the nature of the animal. Even brand new arbors sometimes need straightening.
If you need more questions answered contact us at...
http://www.brakelathe.net/
Mar 14, 2015 | Ammco Combination Disc/Drum Brake Lathe
Must remove arbor housing form pin connecting ito to the cradle
if you can post some pictures, I think I can help you. If you removed the pin there should be nothing holding it from moving. if it is threaded on, try to turn it in the opposite direction than it turns to work in. could you also post the make and model number so I can locate a guide.
Nov 21, 2013 | Saws
I have a DW402 4.5'' angle grinder and do not know how to remove the blade to install a new one. Could someone help please?
On top of the head there is a button to press to lock the blade arbor. Press it down and turn the blade by hand until it locks in place. Then you need either a spanner wrench or nut wrench depending on which arbor nut you have. Grinders usually come with whichever wrench they need. Most grinders have an arbor nut with two or four holes and require a spanner wrench with two studs that fit into two of the holes to remove the arbor nut. Some have an arbor nut with a hex fitting, like a regular nut & bot setup, that the arbor wrench fits on. If you don't have the proper wrench sometimes you can get the arbor nut off with a pair of vice grips or pliers. You will want to turn the nut in the same direction as the blade spins when the grinder is on to remove it. When you put the new blade on, get the arbor nut hand tight, it is self tightening and will get tighter as you use the grinder.
Jul 18, 2012 | Dewalt Saws
I cant tighten the blade on to the arbor arbor is spinning
If your saw is not equipped with an arbor lock, there are several methods of holding the blade while you tighten or loosen the bolt. First, hand tighten the nut to get it snug. Then you can either wedge a Phillips screwdriver shaft between a blade tooth and the base, or you can use a pair of pliers to squeeze the blade and hold it in place against the base. Be careful not to nick the tips of the blade and be cautious with your hands. Obviously you want to make sure you are spinning the bolt the right way, too. You don't need to really crank bolt down, just firmly tighten it and leave it be.
Nov 28, 2010 | Skil 558001RT FactoryReconditioned 7 14"...
Replacing the thermostate
drain out coolant in a drain until below thermostat level follow radiator hose to engine cylinder block to thermostat housing.remove thermostat housing than remove thermostat.replace with a new o-ring on thermostat before installing new thermostat.make sure thermostat housing surface and engine block surface clean.before installing new thermostat.
Aug 16, 2010 | 1997 Isuzu Trooper
7 1/4 B&D saw - blade stalls but motor continues to run
There should be a special washer between the bolt (that holds the blade on) and the blade. If the arbor has a flat side on it, then the washer should have a matching hole so that the washer cannot turn independently of the arbor. Or, some saws use a spring washer which is cupped and becomes flattened against the blade as the bolt is tightened. If you have the first type of washer, perhaps the bolt is just not tight enough. If you have the second type of washer, perhaps the washer is backwards. If you have neither type of washer, you need one.
Jul 28, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Hi, we have a AMMCO 7750 brake lathe, the problem is runout in the ARBOR we have replaced the arbor but still have the same result. We are unsure of hat is causing this so any help or advise would be...
First off--your model Ammco is their "El-Cheapo" model.
Yeah, they work, when they work that is.
I doubt that your problem lies within the spindle bearings. But it could-- I suggest that you tug on the spindle to see if you get any back and forth end-play, or up and down play.... if so, you are screwed. This machine is not worth the effort, money and time fix this problem.
As for the arbor...
This model uses the same arbor that the better 3000, 4000, 4100, 7000 and 7100 models.
Every time you replace an arbor (new or used) you have to...
A. Lap the arbor into the spindle using lapping compound (just like lapping valves in a cylinder head) The lapping compound is then cleaned out of the spindle and off the arbor, then...
B. You then have to check the "runout" with a dial indicator. These are obtained cheaply at Harbor Freight FYI. With the dial indicator mounted (magnetically) on the twin-cutter check the arbor run-out. The runout (two inches from the spindle) should be no more than 1 1/2 thousandths. One thousandth or under is optimal. Any reading over 8 thousandths cannot be straightened.
C. If the run out exceeds 1 1/2 thousandths, you have to then straighten the arbor.
To straighten the arbor you will again need the dial-indicator and a heavy copper hammer....
With a wrench on the end of the draw bar (far right on the end of the drum gearbox), rotate the machine (counter clockwise) until you find the high spot on the arbor (carefully watching the dial-indicator).
Remove the dial indicator and give the arbor a whack with the hammer (not too hard if this is your first time) when the high spot is directly straight up.
Install the dial-indicator and check the run-out again.
Sometimes you will get it on the first whack--sometimes you will have to go through an ordeal until you get the arbor in spec.
And remember--sometimes you can bust the arbor completely off on the first whack. They are hardened and allegedly tempered, but some are more hard than others. If it breaks off--tough luck. You need to get another arbor.
I have personally straightened arbors more than 30 thousandths out (once)... and I don't want to repeat that ordeal. Sometimes arbors cannot be straightened (bent in strange ways) and cannot be straightened.
When loosening a rotor, do not allow the work to dump onto the arbor. This is the main reason they go out of whack.
Buy Sell Used Brake Lathes Brake Lathe Parts
Jun 29, 2010 | Ammco Combination Disc/Drum Brake Lathe
I need to replace my old bath fan, I removed the grill and have no idea how to remove the fan assebly. Th efan is about 25 years old
There should be one or two screws somewhere in the box. This will allow the fan housing assembly to be removed from the base box. When the screw(s) are removed the fan housing may have to be pried down a bit. There are usually two tabs on the opposite side of the screws which allows a hinging type motion to swing the unit out. The main housing will have a woodscrew attaching it to a nearby cieling joist . You will have to remove the output host from the box also. Then you can replace whole unit with better unit,
Feb 19, 2010 | Dryers
Manual for #103.0205 circ. saw
Earlier comment 103.0205 Table Saws does not need lubrication is simply wrong.
The103.0202, 103.0203, 103.0305 Craftsman Companion Table Saws main Arbor axle DOES have to lubricated or else the axle bearing will quickly loosen side-to-side or vertically and fail to provide accurate saw cuts.
FWIW, Sears no longer sells Arbor Axle replacement parts... The Table Saw Arbor axle and Bearing Housing cannot use sealed bearings unless the saw case is re-milled and extensively modified. There are 2 Oil Hole Plugs (part# 475-32) that need to be opened and oil applied so the Arbor axle shaft does not get scored or worn.
I use 30wt motor oil to relube the Arbor Axle Shaft depending on amount of use, temperature, and axle rotation stiffness.
Remember, the higher the RPM speed of the table saw motor and/or the longer the use, the more frequently you may need to relube the Arbor Axle Bearing!
Nov 19, 2009 | Sears Saws
How do you remove the arbor assembly on a craftsman 10" table saw
go to sears service center and get a new arbor, and ask them to show you the motor and arbor assembly drawing. it should show how the arbor is attached to the shaft.
you can pull the arbor off with a pulley. you can get that from auto parts store.
Mar 31, 2009 | Craftsman 10" Table Saw
Saws Logo
78 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
