Question about Dell 3010cn Laser Printer
I have a Dell 3010 that has error msg paper jam fuser 077-104. I cannot find a paper jam anywhere in the printer. I turned it off, unplugged, checked under drum, opened all doors and checked everywhere. When I plugged it back in and turned it on, it still says same thing.
    Sergeant:
    Champion:
  • 387 Answers
You need to check the fuser, sometimes a small piece of papaer or a label stick on he fuser in order to do this you need to open the back and top cover. or take the printer to service
Posted on Aug 21, 2010
Testimonial: "when I finally figured out where the fuser was,there was paper rolled around roller. I carefully unrolled it with its feeder wheel. Its OK now. TU "
There is visibly no paper jammed have checked removing the cartridge.yet I get A msg that the paper is jammed
Have you check paper jam from the fuser? You have to open the fuser door which is at the back (on the rear) of the printer, after pulling out the fuser, you'll be able to do that.. Also check the paper carriage (passage after the Tray).
If there's nothing, then, remove the cartridges and shutdown the printer, leave it off for few minutes and then again restart it while pressing the power button and if the error still there, press the "Go" or "Ok" button and see if it helps or not..
Good luck.
Thanks for using FixYa.
Jun 22, 2010 | HP LaserJet 1018 Printer
202.01 and 202.03 Paper Jam
The 202.03 error code has to do with an early life failure of the fuser. Try replacing the fuser. If that doesn't work, a tech is needed to replace rear door. Don't forget to reset maintenance counts when you replace fuser!!
Jul 01, 2009 | Dell 5310n Laser Printer
Paper jam msg. in Canon mp530; doesn't appear to b a jam though
look for a paper jam in the front and the back of the printer. open the compartments and take a look. if all is clear unplug the printer and then plug it back in. this will reset it. good luck.
Jan 16, 2009 | Brother MFC-3240C All-In-One InkJet...
Lexmark X6570 printer - Cleared paper jam. No paper scraps visible anywhere in printer. Continue to get error message to clear paper jam and then press the "check" button. Does not reset. ...
Ok, the paper jam could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Nov 11, 2008 | Office Equipment & Supplies
Printer now not printing, as it says there is a paper jam
it sounds as though your pick up rollers are worn. when the oprinter can not pick the paper from the selected tray (tray 2 in your case) then it shows up as a jam. to sort this you will need:
One of these: RM1-0036-020: PAPER PICK-UP ROLLER ***'Y
Two of these: RM1-0037-020: PAPER FEED ROLLER ***'Y
Hope This Helps
Pete
Oct 30, 2008 | HP LaserJet 4250n Printer
Printer jam
unplug the printer from the computer , disconnect the black box the power adapter from the back panel of the printer , turn the printer upside down and then gently tab on the printer . Clean and manually roll the paper tray rollers . open the printer cover and look for any obstructions , remove the cartridges and clean them using a damp soft cloth .put back the power adapter and try to copy something , if it still displays the same error msg then its an issue with the printer and you need to purchase a new one.
Do lemme you if it helps.
Jun 26, 2008 | Dell 922 All-In-One InkJet Printer
Dell 924 printer paper jam; don't have a # sign or number to reset
Hi
If there is a error msg on the operator panel of the printer, try the following steps
1.press and Hold the start button and the cancel buttom on the printer and holding them down unplug the Power adapter from the printer , wait for abt 30 secs and then put back the power adapter and then release both the buttons.
2. manually move the rollers present inside the paper tray, lift the printer and shake it firmly , turn the printer upside down and gently tab on it , put back the power adapter and then turn on the printer , if it still gives the same error msg , then purchase the new printer
Apr 21, 2008 | Dell 924 All-in-One InkJet Printer
Won't print - says 'paper jam 2' but no paper is stuck in machine
Paper jam 2 error code is saying the jam is in the fuser area of the machine.
You need to remove the toner cartridge, and since you said you've taken the whole thing apart, maybe try a flashlight and look for a LITTLE piece of paper that may have torn off that remains stuck around that fuser area (the fuser is the thing behind the toner that gets hot-- so be careful -- but look in the corners and anywhere a small piece of paper could have torn and got stuck.
If you're absolutely sure that there is nothing stuck, I'd try to do a hard-reset: Turn off the machine, unplug the power cord and the cable that goes to your computer (if it's hooked up to one. And if it is hooked up to a computer, power down the computer as well.) Wait a minute or two, plug the computer back in, plug the power cord and cable from the printer back in, then turn on the printer and the computer and let them both go through their various start-ups.
If none of that works, let us know.. but from what I know and the docs I have access to, it should work... (fingers crossed!)
Good Luck!
Maggie B
Feb 22, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Error Msg: PAPER JAM in Brother MFC-8840D
one of the jam switchs is stuck down or paper concertina in fuser assy
Dec 28, 2007 | Brother MFC-8840D All-In-One Laser Printer
Dell 3010cn Laser Printer Logo
639 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
