Question about Jet 7 Portable Power Chair
How do i remove chair from jet 7there is no safety latch i believe its an older model of jet 7 not sure because its a loaner i see no safety latch on seat
SOURCE: The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Posted on Mar 13, 2009
dromtonpa
  • 40 Answers
SOURCE: JET 3 POWER CHAIR SEAT REMOVAL
Sometimes it just takes some real elbow grease to remove those. Try two people one on each side.
Posted on Mar 31, 2009
SOURCE: All six lights blink on my Jet 3
I just had the same problem with my uncle's power chair. The number of "blinks" indicates a problem code to the technicians. My chair needed the joystick control assembly replaced. Once replaced, evrything was back to normal. 'Not a cheap fix but much needed. Good luck my friend!!
Posted on May 06, 2009
  • 103 Answers
SOURCE: How do I get the battery out of the wheel chair
Take the seat off and the batteries should lift out
Posted on May 26, 2009
  • 175 Answers
SOURCE: How do I remove the chair from my Pride Mobility
There's a lever on the side of the chair that you disengage to unlock it. First, make sure the chair is in gear and power is off, then unplug the Joystick from the base; just follow the cable coming out of the joystick to the rear of the chair where it plugs in and rock it back and forth to unplug.
Unlock the seat with the lever, and turn the seat slightly to the left or right and lift up. Usually, it will come right off. If it's been a while since it's been removed, or if a heavier person has been bouncing atop it, it may need more coaxing. Try squirting some WD-40 at the base of the seat where the pole connects and let it run down into the shaft of the pole. Wiggle seat back and forth a bit and try lifting at the same time.
Now you can access the batteries by lifting up on the corners of the cover called the shroud. These are held on by Velcro strips so just pull up and they will give way. You will see the two batteries inside. Replace them with sealed, gel-acid deep-cycle batteried, about 32-34 amp-hour rating. Fully charge for two or three hours before using. On first uses, let the batteries discharge almost to the red zone before charging overnight. After a week, they will be well broken in. Good luck.
Posted on Jul 11, 2009
My mom has a Jet 3 Ultra and by reading other comments it sounds like we need a new battery, so I have 2 questions: 1 - where do we buy the battery 2 - how do we replace/install the battery - can we...
Did Medicare pay for Mom's chair? If they did then they will pay for 80% the repair to the chair. You can contact Repair Express @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 they are both excellent repair companies and will schedule a tech to pick up mom's chair leave a loaner and fix the chair for her. Now if Mom bought her chair then she will have to pay for the batteries and all other repairs needed (lets hope not). The chair needs 2 U1 sealed batteries and they can be purchased through the provider where she got the chair or at any good battery outlet like Interstate Battery. I would avoid Internet stores because of the shipping costs. Do not get them from Wal Mart or any other chain store because they do not sell sealed deep cycle batteries required for your chair. The batteries will cost you around $200.00 for both. The provider will probably charge you more. You have to unplug the joystick cable, remove the seat from the base and take the shroud off the base and there you will see the 2 batteries. Remove the wiring harness and remove the batteries reinstall the new batteries wiring them like the old ones, replace the shroud and the seat hook up the joystick cable push the on/off switch and pray that it comes on (lol). The old batteries can be recycled through any battery dealer in your area Hope this helps. If you have any questions you can reach me @ lennieg2000@yahoo.com
Mar 15, 2011 | Jet 3 Ultra Power Chair
When i turn the on switch three red lights flash on the left side
glenn You have a left motor fault and the motor will have to be replaced. If Medicare paid for your chair they will pay for 80% of the repair costs. Contact Repair Express @ 877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 they are both great service companies that will send a tech out to pick up your chair and leave you a loaner to use. They will bill Medicare for all repairs and get your chair back to you all ready to go You can also check with your provider to see if they will repair it for you Hope this helps
Mar 01, 2011 | Jet 3 Ultra Power Chair
Lite Blinks continusleyon control ,chair will not move
I am assuming you have a Jet 7 with a VSI controller (manufactured by Penny and Giles) with a steady flash of all the speed and profile LEDs (lights). This is a no drive away feature of the VSI if the charger is plugged in. The older Penny and Giles controllers indicate the same flash code.
If you have an on- board charger check to see if it is plugged into the wall. If it is, unplug it and see if the chair runs. Sometimes, you have to remove the back cover and unplug the charger haress at the output of the charger inside the electronics housing (much more difficult). A failed on-board charger can inhibit the VSI controller (no drive away) even if it unplugged from the wall outlet. There is also a charger inhibit harness with a fuse that might have failed. A qualified technician can jumper this harness to bypass and test.
If you have an off-board charger unplug it from the wall or unplug it from the charging port in the front of the VSI. If the chair runs in either case you have a bad charger.
You may also have a bad VSI controller which can be rebuilt or replaced. Start with the basic charger unplug tests and then work your way to the VSI controller. Hope this helps.
Nov 20, 2010 | Jet 7 Portable Power Chair
Doesnt charge
well you wil ned to call the company who sold you the cahir and they will send for some one to fix the problem or change the chair this problem is commo in some chairs.
BE SURE TO HAVE YOUR PURCHASE INFORMATION I ORDER BEFORE YOU CALL
Feb 11, 2010 | Jet 7 Portable Power Chair
Need to remove the bad batteries Jet 3 power chair
Hello Donald ,
You may have solved this problem by now ,but just in case you have not, here goes.
Make sure the chair is turned off and engauged in the drive mode meaning not in the free wheeling mode. This way it will not roll around on you during the battery change out.
Go to the rear of the chair and slightly turn the two black plastic lock pins,one on each side they actually lock the small )) shaped cover in place. Turn these with your fingers or you can also insert a dime in the slot on top of each pin to turn them . You will be able to tell when they have unlocked as the )) shaped cover will be loose. Lift the cover up and under it you will find the battery connector, unplug it and leave the cover off for now.
Next ,move to the front of the chair and just to the rear of the footplate you will find a locking pin that runs through the lower rear bar of the footplate as well as the chair frame itself . Pull this pin completely out. Once done you should be able to pull the entire footplate assembly out torward you, Black plastic front cover included. Once you have it pulled outward lift it upward and it should lift completely off the chair. This done , you should actually be looking at the front battery which is sitting in a black plastic tray. Gently but with a firm grip grab the tray anyplace you can and slowy begin to slide it out from under the chair torward you taking care not to tangle the battery connector at the rear with any other wiring on its way out. Once you have the tray slid out into the open ,you will be looking at both batteries after which you will need to unhook the straps that secure the Batteries to the tray after which you will need grab your wrenches and remove the battery harness itself from each battery. You may want to do just one battery at a time this way you'll have less wiring to keep track of when wiring in the new Batteries. The Batteries in your Jet 3 are a size known as U-1 deep cycle sealed maint. free batts, You can use either Gel Cell or seale3d LA replacements . Though they are much cheaper, you cannot use lawn tractor batteries. Though they look the same the internal technology between medical powered mobility batteries and tractor batteries are entirely different. The latter would only run your chair for maybe a half hour or so before needing charge.
Take great care to make sure your wiring hookups are correct and that you position the rear connector plug to the rear of the tray. This way you will be able to locate it easier once you have slid the tray back in under the chair and it is time to go to the rear of the chair and reconnect that plug. As for everything else ,reattach it in reverse of the way you removed it including remembering to slide the lockpin back into the front footplate frame. Give a tug on the footplate when done to make sure it is locked and secure.
In closing I offer this valuable advice : When working with any of these batteries, always were safety glasses or goggle and gloves (terminals are lead). I also advise removal of metal rings ,watches, bracelets etc that could create a short when reaching in and around the battery terminal. Take great care with your tools and wrenches in making sure you keep and eye on both ends of the tools at all times. This way you will not accidentally cross the posts of the battery. Take your time ,use proper safety technique and you'll do fine. The following is Pride Mobility's step by step for battery change out and is basically the same as I have sent . Can never have to much info but can always find yourself with not enough. Take Care
To replace the batteries:
1. Turn off the power to the controller.
2. Make sure that the power chair is in drive mode. See III. "Your Power Chair."
3. Turn the rear shroud fasteners one-quarter turn in any direction. See figure 6.
4. Remove the rear shroud.
5. Unplug the battery connector. See figure 26.
6. Remove the retaining pin from the foot platform and lift the platform up and away from the power base. See figure 19.
7. Slide the battery tray forward.
8. Unfasten the reusable strap around the front battery.
9. Disconnect the wiring harness from the front battery.
10. Remove the front battery.
11. Unfasten the reusable strap around the rear battery.
12. Disconnect the wiring harness from the rear battery.
13. Remove the rear battery.
14. Place a new rear battery on the battery tray. Make sure that the terminals are facing forward.
15. Fasten the reusable strap around the rear battery.
16. Connect the wiring harnesses to the rear battery.
Apr 30, 2009 | Jet 3 Ultra Power Chair
Apr 28, 2009 | Jet 3 Ultra Power Chair
WHAT MAKES THE CHAIR NOT MOVE WHEN CHARGING?
You cannot make a powerchair operate while it is charging. For safety purposes the power cuts out when charging batts. The only power is going to the batteries.
Feb 26, 2009 | Jet 3 Ultra Power Chair
Bolt broke that holds saftey seat latch on - where to get parts?
one of the best places my be a Automovtive supply stores , you may also try a Home improvement store, they tend to carry "odd" Bolts, to remove the broken bolt you may have to drill it out with a special drill tip also avaliable at most of the Home Improvent stores,, make sure you take your broken piece with you if you still have it so you can get a perfect match.
Jan 31, 2009 | Jet 3 Ultra Power Chair
Jet 7 Portable Power Chair  Logo
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
