Question about Kenmore 700 sq. in. Cooking Area Gas Grill 14116325
Kenmore model 141.156400 I just bought new gas collector boxes I can see the spark but only one burner (the last one) will light
4 Suggested Answers
  • 4 Answers
SOURCE: Kenmore gas grill 141-16228
There is an Englewood, CO, retailer called Appliance Factory Parts. They sell parts for discontinued and old model gas grills.
www.appliancefactoryparts.com, at (800) 955-7075. The burner can be obtained from them or a local gas barbeque store (I found out they are interchangeable with new model grills), but the grilling and lava rock grates/grids were hard to match and I got them from Applied. I rebuilt a 1992 model Kenmore grill.
Posted on Jun 19, 2008
  • 3 Answers
SOURCE: Kenmore elite16690 gas grill - main burner replacement
Call 1-800-4MYHOME and request a brochure for that model. Then you can call the Parts line at the same number and order the parts you need.
The actual grill model number is 141-16690
Posted on Sep 08, 2009
  • 43 Answers
SOURCE: Kenmore Gas Grill will turn off after three burners are on.
replace the gas regulator the hose connector to propaine tank
Posted on Jan 08, 2010
How do I get burners to ignite without using matches? (electrodes/sparkers work fine)
Gap distance and fuel pressure are important, also make sure the area is clean by the ignitors
Sep 29, 2016 | Kenmore Kitchen Ranges
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Kenmore Gas Range Model 790.7851 - top burners have gradually stopped working over last 6 months, appears to be low flow of gas but did not occur all at once, happened at each burner one at a time. Now...
you will notice small holes around your burner. Look at the burners holes next to your spark igniter. A paper clip will fit perfectly into the small hole to clean them. This is very common, boil overs clog these holes with debris and does not allow gas flow to ignite properly.
http://www.on-timeappliance.com
Mar 28, 2012 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My kenmore gas oven won't lite. I'm not sure if it's the electronic ignition since I don't hear any clicking noise. I just bought this stove it is used and about 8-10 yrs old. Is this something I can...
This sounds like a possible spark module problem it sends the correct voltage to the correct burner and if faulty sometimes wont light the burners atall. generally a gas technician would diagnose such a problem so i WOULD NOT recommend doing this yourself although no ``gas`` parts may be involved. I would need the correct model and the first two digit of the serial to search for a part number for you. hope this helps
Thanks
Oct 11, 2009 | Kenmore Kitchen Ranges
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
New cooktop-1 burner does not light automatic
find the spark module. Follow the spark wires to the module . unplug the one that doesn't work and plug in a working wire. If it sparks it the wire if it doesn't spark change module
May 16, 2009 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Kenmore Elite 30" gas cooktop installed. Large right front burner
There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
Feb 11, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
May 03, 2008 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Kenmore Master Flame Grill
Burner will not light:
Here is a couple things you can check:
1. Gas injector not insert in venturi tube.
2. Clogged gas injector
3. Obstruction in gas line.
4.Spider webs in venturi tubes.
5. Misalignment Of collector box and burner.
6.Dead Battery.
7.Check hose to make sure it is not kinked
8.Check Hose to make sure it wasn't chewed by squirrles
9. If it is LP gas, Could be out of gas.
Other Issues:
Could be the way the grill was turned on and off, that also can be an issues. In your manual it will tell you how to do it proper, this could make it not light or have a low flame. If there is not hing in your manual, I will be happy to assist you.
Fireplace-Girl
Mar 16, 2008 | Kenmore 16225 Grill
Kenmore 700 sq. in. Cooking Area Gas Grill 14116325 Logo
136 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
