Picture on tv has a horizontal line at center of tv and wanted to see how to fix on sylvania 27 inch tv.
  • 8,617 Answers
Replace the vertical output IC
Posted on May 03, 2008
The picture is just small line in the middle of the screen , still as sound
Hi, if the line is from top to bottom, that is the horizontal circuit transistor problem;/if the is left to side that is vertical deflection ic driver and some capacitor to replace and verify soldering arround
needs to be fixed by a real tech..
have a nice day
hope that will help you.
Apr 07, 2010 | Sylvania 6727DE 27 in. TV/VCR/DVD Combo
My 27" ( aprx 6 yrs old)Tv first had only a horizontal line across the screen about 1/2" wide, good sound but no picture, now it only clicks like its turning on and off when you plug the tv in, no pictue...
It has gone into a self protect mode where it will shut down because you have a fault in the frame stage of the TV (horizontal line). This will most likely be a failure of the frame output IC. Replace this & you should restore the normal picture.
Oct 11, 2009 | Sylvania Televison & Video
Sylvania 6842PE 42 inch Plasma Fuzzy picture and horizontal Lines
USUALLY THIS PROBLEM IS CAUSED BY A DEFECTIVE X OR Y SUSTAIN BOARD. ESTIMATE BETWEEN $300- $700
Apr 03, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
27" sylvania stereo television
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace. You'll need to take your set to service center to have it serviced.
Good Luck!
- Jim
Jan 26, 2008 | Sylvania 6427TE 27" TV
Sylvania 27 in tv picture
It sounds like your vertical has shrunk, causing the picture to look squashed. Most likely a bad component in the vertical output stage.
Dec 19, 2007 | Sylvania 6413TC 13" TV
Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Nov 10, 2007 | Sylvania 6427FF TV
Tv screen
hi there, working sometimes means there's a lose solder at the vertical section. see the vertical ic, check the board for some lose connection and cold solder. do some test. ty
Nov 09, 2007 | Sylvania 6427TE 27" TV
Horizontal line (with about an inch of picture)
check a capacitor on the horizontal section
Oct 28, 2007 | Toshiba 27AF43 27" TV
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
