Question about Bosch HGS442UC Gas Kitchen Range
I have a bosch gas range/oven #HGS7152UC-03 Came back from a 1-week vacation and found the display panel off. Unit is plugged in, circuit breaker in basement did not trip (it's on). The range burners will turn on (I believe they are electric); But the oven will not work. All oven controls are operated through the touch pad/panel and it is off and doesn't respond to any touches. I have heard that power outages are a problem for these fancy ovens...it's possible we had a power outage when I was away, but the microwave clock didn't reset so I'm doubtful that is the problem.
bestdarngood
  • 3037 Answers
SOURCE: Oven does not heat but broiler does
The most common cause of this symptom is a defective ignitor. Oven ignitors can glow and allow enough current through to open the oven gas valve but just not produce enough heat to ignite the gas immediately (see the link below).
In that case, replacing the oven ignitor is the usual solution.
http://www.appliance411.com/links/jump.cgi?ID=823
Posted on Mar 22, 2008
  • 417 Answers
SOURCE: We have a Bosch fan
It is possible that the after turning off the electricity the oven has reset in AUTO (timed cooking ) mode, try setting it back to MANUAL mode and try the oven again
Posted on Oct 21, 2008
  • 3 Answers
SOURCE: MY BOSCH ELECTRIC RANGE NOTHING WORKS, GET POWER NO HEAT
u may need to set ur clock to manual operation. check instructions if u hav them
Posted on Feb 06, 2009
SOURCE: My Bosch gas free standing range is HGS232UC. The
Hi, well whenever a range will not work in the area of the Oven itself, well it is only one of a few things, it maybe the Thermostat, Temperature Sensor, or main controller board, it may also be a Gas problem, a blocked burner jet etc,but this is unlikely? these suspected components must be tested to find the faulty part, replacement is the only option.
With a GAS appliance, legally a professional MUST be used for safety reasons Therefore i would recommend that you contact a Bosch service center and ask for a service call, if worried about costs, and who isn't? please simply ask them for a "Quote" first, now once you are appraised of these costings you can then decide what to do.
Posted on Jun 24, 2011
SOURCE: Bosch gas range HGS7052UC touch and turn panel not
My touch panel is not responding. It just flashes numbers to set the clock. I can turn the dial to set the hour only. Can't touch start...does any
one fix there panel? where and how much it cost.?
Posted on Jun 05, 2012
How do I clean the control panel on my Bosch range without activating oven settings?
Turn off the circuit breaker to the oven before cleaning the control panel.
Dec 24, 2014 | Bosch HGS5052U Gas Kitchen Range
Touch keys on Bosch built in over HBL33 not responding
Not sure about your model but I have a bosch hgs7152uc model. I found that removing two screws and the metal panel in rear of the stove (at top where display is) will provide access to the control panel. There are four screws holding the display circuit panel in place. Two of the screws were not tight which allowed the circuit panel to move backwards when pressed. Tightening all four screws made the display operational again. The screws had lock tight on them but apparently they came loose anyhow over time
Oct 26, 2013 | Bosch HBN 442 / HBN446 Electric Single...
HGS7152UC bosch oven door won't seal
Oven doors are designed to have some movement in and out to accommodate sealing against the gasket. If you're not getting a good seal check the condition of the gasket. If it's hard and inflexible you'll need to replace it.
About 5-6 years of normal use can make these hard and inflexible.
I just looked and Bosch calls this the 'Door Seal' pn 1052639
Jul 30, 2012 | Bosch HGS442UC Gas Kitchen Range
Have a Kenmore Electric Range Model- 790.4671. Ran the self cleaning program. Error occurred at the end of cycle. F10 and F30. Oven will not unlock. Show oven locked and a picture of a lock. Oven is...
Sorry to read about your problem
Your F10 code means Runaway Temperature and f30 means open probe connection. try this and see problem comes back.
1. Unplug the unit or turn the circuit breaker off for 60 seconds.
2. Now, restore the power to the appliance by plugging it back in or turning the circuit breaker back on.
3. Check to see if the error code is still displayed on the range.
Note: General information for resolution to this problem, is based on information provided in question. Contact certified technician if problem persist. Sears Repair 1-800-469-4663
I have tried to help you.Pleas help me by Vote/Rate my response. Thanks.
If you are in the Denver,Co area I can help you out.
Dec 20, 2010 | Kenmore 46713 Stainless Steel Electric...
Gas top works-- all electrical is gone-- no ovens, no display panel
Try to find your circuit breaker box and see if any of the circuit breakers are tripped. If one is, push it to OFF then back to ON. If none are tripped and you know which double circuit breaker controls the oven, turn it OFF then back ON. If you know how to use a multimeter, check that you have 240 volts to the range outlet.
Dec 10, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
No Power to FGF366ESB Range
althougy ou cked circuit breaker did you try unplugging unit waiting 2 min then plugging back in. sometimes you get lucky and will reset. has to do with high voltage bleeding through to low voltage wiring. if it works, your good!!!! if not remove the back panel and check the clock/control for icoming power. as long as you have 110v going in at the black (L1) you should have a display. if you have powerand no display you need a new control.
Mar 13, 2008 | Frigidaire FGF366E Gas Kitchen Range
Error code
Try unplugging or turning off the breaker for 30 mins then plug it back in and see if you still have the 160. I'm surprised that it doesn't have an F anywhere in the code. How old is the oven. Could some of the lights on the control be out. they are LED's and sometime they do burn out. I'm thinking this could be an F06 code which could mean anything from a power surge (clock) and needs to be reset (like I said by switching of the breakers or unplugging) to an EOC (Electronic Oven Control) failure. By switching off the oven and waiting about 30 mins. if it doesn't come back on it will be the EOC. make sure the LED (light emitting diodes) aren't out on the control making you
Dec 20, 2007 | Bosch HDI7282 Dual Fuel (Electric and Gas)...
Oven control panel
Lok at your manual tp view all the possible control options. However, the solution could be; The touchpads, in conjunction with the dial, are used to select an oven mode,
set the oven temperature, set the time(s) and to set up your range. To use the
touchpad, press the center part of the pad with the flat part of your fingertip. A
beep will sound to indicate that the selection has been made. Turn the dial to the
desired setting and press START.
Pull the plug or flip the circuit breaker, wait five seconds and plug in the range or flip the circuit breaker to on. Always set the clock after installation or after a power failure. Once power returns to the oven, the clock defaults to 12:00 am.
Clock time display can be turned off. The default display is on.
1. Access SELECT FUNCTIONS Menu.
2. Turn knob clockwise until CLOCK DISPLAY is displayed.
3. Press START.
4. Turn knob to select ON or OFF
5. Press START to accept new selection.
Reset the Factory Settings This feature is used to change all the “Select Functions” settings back to the original factory settings (or defaults).
2. Turn knob clockwise until RESET DEFAULTS is displayed.
3. Press START. Display reads SELECT FUNCTIONS.
Dec 03, 2007 | Bosch HES 24 / 6HES 242 / HES 247 Electric...
Bosch HBL745A Oven door
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Nov 14, 2007 | Bosch HBL 742 / HBL 746 Electric Single...
Bosch HGS442UC Gas Kitchen Range Logo
7,897 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
