PHILIPS MAGNAVOX RED RETRACE LINES AFTER 8 MINS.
PHILIPS MAGNAVOX : MODEL 55PP9401 SET PLAYS FINE FOR ABOUT 8 MINS. THEN COMES THE RED RETRACE LINE, THEN SHUTS OFF.
CHECK THE SCREEN CONTROL BLOCK SEEMS TO BE GOOD (SWAPED RED & GREEN SCREEN LEADS).
COULD NOT SWAP THE SOCKETS , THEY HAD DIFFERENT CONNECTIONS.
SO I BROUGHT IT IN.
ANY IDEARS??.
  • 8,617 Answers
You could have either a bad CRT drive circuit or a shorted red CRT. If you need parts , here is a site that has both parts available used that they sell cheap and ship for free and any used part is guaranteed. Heres the link drop them an email they will get back quickly.
http://servicemanuals.vstore.ca/
Posted on May 03, 2008
We have a Philips Magnavox Model #TP3284C101 TV and plugged in a Durabrand DVD Model #DVD1002 player to it. It will only play in black and white on this TV. But when we plug the DVD player into another TV...
It sounds like you have a standard problem.
Is the TV you are using, that gives the black and white picture, the same as the other ie, both NTSC or PAL and both on RGB or Y-C or S-Video?
Check to see what is required and set the DVD player accordingly.
Hope that helps.
Dec 10, 2010 | Philips Magnavox 27MS343S 27" TV
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
Intellisense button
If the model number on the set is 55PP9401/55 you have an interesting set----this model says Philips but was made by Hitachi---they made them for Philips for one year while Philips was gearing up to produce their own sets---very good set and is better than the Philips sets that came after it.
It uses (if it is this model) two STK-392-110 CONVERGENCE IC's----both need to be replaced and the set adjusted---no need for an original remote---with the set engaged in the convergence adjustment mode( there is a micro switch on the front of the main circuit board) A HITACHI REMOTE CAN THEN BE USED TO ADJUST THE CONVERGENCE. Hope this was helpful.
Aug 11, 2009 | Philips 55PP9401 55" Rear Projection...
SET WON'T POWER UP
i hate to tell u but maganvox bigscren are not ment to be repaired so now i said that i need the model number on the tv to help u but most all magbavox phillips and sylvania tvs most of them are big screens u have to buy the hole board from magnavox and it cost as much as the tv did. but i will try and hp u if u get me the model number and i need to know if u turn the set on and wait 2 mins and trun it off do u see and thing on u screen at all please let me know marty
Oct 13, 2008 | Philips 55PP9401 55" Rear Projection...
I have a phillups projection tv and it totaly kaput
u lost convergence witch is no big deal with magnavox what i would do first is change the convergence ic that should sole your deal
Sep 22, 2008 | Philips 55PP9401 55" Rear Projection...
Have power but no sound or picture
Do you have high voltage? Check by turning up one of the screen controls to see if you have retrace lines.(pinstripe diagonal lines across the screen) If present turn the screen control back down until the lines just disappear. Check diodes 6003, 6012, 6025, and resistor 3669. If you don`t get a retrace line by turning up the one of the screen controls, check for missing voltages or shorted components in the horizontal output and power supply circuits. Note: Philips TV`s can be tricky even for experienced technicians. Good luck
May 22, 2008 | Philips 50P8341 50" Rear Projection...
Philips magnavox 32" TS3260C1
Sounds like retrace lines. Leaky caps or worse can cause this.. Are you getting any vertical foldover at the top of the screen?
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
Philips 55PP9401 Green Out?
This is a PP15 Philips Chassis Designation.
It's based on the DP15 Hitachi Chassis w/ Different Micro.
Hitachi DP15 Model: 53UDX10B
It's most likely that the convergence amps have failed and if you have little experience in electronics I'd STRONGLY suggest you take this one to the shop.
This set takes two STK392-110 Ics and it's recommended you upgrade those to the STK392-150s for greater reliability.
They make a nice kit complete with all conv. Ic's and all (6) resistors and complete instructions. Tritronics carries them part # X480295 (Jt22053 Repair Kit).
Bill
Nov 24, 2007 | Philips 55PP9401 55" Rear Projection...
Green horizontal lines
Hi, I have a Philips 29PT9009/12 TV. Recently I have begun to see horizontal green lines on my tv, when either watching a dvd or watch tv. This has gotten worse and now the green lines are more visible and the background is now turned a shaded green. Please help me. Thanks in advance
Apr 30, 2007 | Philips 28PW6506 28" TV
Philip Model 55PP9401
The Green is Standard, meaning it is what you should lign the red and blue up with. But if it's not true in shape there is something wrong with the green.
Nov 28, 2006 | Philips 55PP9401 55" Rear Projection...
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
