After installing cd and following directions to install my Linksys wpm300n wireless-n pci adaptor the directions say to power down pc,installcard hookup antenna and re power up pc.but i get no futher set up directions from the instalation cd?
    Sergeant:
  • 221 Answers
Click on Start - right-click on my computer - click on properties - click on hardware - click Device Manager
Look for your wireless adaptor in the list. Probably under Network adaptors. If it is on the list and there are no yellow question marks or Exclamation points next to it then you have successfully installed the device.
If there is an item that says unknown communication device with a yellow question mark next to it (?), put the set up disk back in and reinstall.
Most of the time when you install a new device in a pci slot, you must install the device physically in the computer first before running setup.
Posted on May 03, 2008
Fitted a Linksys-g 2.4 ghz pci adapter to my kids pc, take make their PC wireless, installed the correct drivers after researching what these were on the internet and all ok. Changed ISP and no longer...
If your modem(the device given by your ISP) connected the linksys router on WAN port just power down all devices and power on modem and make sure all lights are on and then power on linksys router. This should fix most problems. If no luck connect your computer to modem directly and check if you are able to log on to internet! If your modem is not working then your ISP is the best option to call!
Sep 11, 2011 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
Linksys wireless doesnt work
Hi there im tech guy from Linksys Well here is your answer For Win xp Operating System
First of all Insert the Adaptor's Cd in the computer where you want to install the w/l adaptor and plugin the adaptor.
Click on Start - Control Panel - Add/Remove Progs. and Search for software which shows some thing related to W/l moter or Compact W/l - or Network Magic / lela - Uninstall the software from list.
Now after that dont restart the computer - It will show u found new hardware Wizard.
The settings you need to go - No not at this time.Click next - Select Recomended - Click Next - Finish Installation.
Able to see the pop up down ryt side click on that link will show you yur network name - High Light and connect. Hope it will resolve your problem ley me know if facing any more problems.
Tech Guy
Cisco by Linksys
samson
Mar 31, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Computer crashed, reset to factory, lost info for linksys adaptor
If you download them to the desktop of the laptop and burn to cd or copy to flash then you may have something going. See if they will d/l to desktop from linksys site.
Mar 15, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
Linksys Wireless-G Adaptor - downloaded driver but can't install
Please don't snap lol no really go to linksys.com and download all you need.RICHARDM69
Feb 04, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
I installed a linksys wmp110 wireless adapter into my gateway and it causes the computer to freeze up. i removed the card and the computer works fine. what can i do?
Reinstall Drivers
To re-install the wireless adapter’s drivers, you need to perform two steps:
  1. Uninstalling the Previous Drivers
  2. Reinstalling the Drivers
Step 1:
Click Start, All Programs or Programs, and look for the model number of the Linksys Wireless Adapter.
Step 2:
Look for Wireless Network Monitor and select Uninstall.
Step 3:
Wait for the Install Shield Wizard to complete before re-installing the drivers.
NOTE: Before re-installing the driver, unplug your LinksysWireless Adapter. If you’re using a wireless PCI adapter, shutdown thecomputer then remove the adapter.
The screenshots may vary depending on the model number of your wireless adapter. In this example, we’re using WUSB54GS v1.0
Step 1:
Insert the Linksys Setup CD into your CD-ROM drive.
Step 2:
Click Here to Start
to begin the installation process.
Step 3:
Accept the License Agreement by clicking Next.
Step 4:
Insert the wireless adapter into your computer and click Next.
NOTE: Ifyou’re using a wireless PCI card shutdown your desktop PC and open yourPC’s case. Locate an available PCI slot on the motherboard then poweron your PC.
Step 5:
When Linksys Wireless Network Monitor appears, select the name of your wireless network or SSID and click Connect. If you want to configure the adapter manually, click Manual Setup.
NOTE: To check if the drivers were properly installed, checkif the Linksys Wireless Network Monitor reports the Adapter is Active.For instructions, click here.
NOTE: If you were not able to install the Linksys adapter drivers, you need to update the drivers.
Update the Drivers
To update the wireless adapter’s drivers, you need to perform three steps:
  1. Downloading the Drivers.
  2. Uninstalling the Previous Drivers.
  3. Installing the Updated Drivers.
Step 1:
Before downloading the drivers, make sure your computer has an activeInternet connection. If your computer is plugged directly into therouter and cannot get online, disconnect your router and plug yourcomputer directly into your cable or DSL modem.
Step 2:
Once online, click here to go to the Linksys Downloads page..
Dec 16, 2008 | Computers & Internet
Cannot connect to my laptop with a built in wireless.
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Jul 13, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
System do not reconize the PCI card
Does it ask for a driver to be installed? Or have you got the wireless version of the mobo that needs an ASUS WiFi-b add-on card with an omni-directional antenna?
Like on the previous version of the mainboard, the PCB contains five PCI slots and an exclusive WiFi slot, in its left part. By the way, when you install the original WLAN card from ASUS into this slot, the last PCI becomes unavailable. Now let’s examine the card, too.
The card supports the wireless networking protocol IEEE 802.11b, describing data-transfer rates up to 11Mb/s. Using the software that accompanies the card, you can use it in the Ad Hoc as well as in the Infrastructure mode, and the card can perform the functions of a programmable access point, providing connections to 31 clients. Thus, the owner of the WiFi-b kit can easily deploy wireless networks and connect to existing ones.
Jul 11, 2008 | ASUS 802.11G WIFI-G 54MBPS WIRELESS LAN...
I have an HP computer (Vista Home Premium Software) and Linksys wireless-G Broadband Router (WRT54G) installed and working. Problem--Trying to makea working wireless connection with a 2nd computer. An...
check that you have all updates for your linksys and cable modem and the new adapter you bought since your pc is old..
if that doesn't help then try the following:
i would shut down pc, uplug router power, turn off the cable modem and give it all at least 10-20 secs.. plug the other pc in the router then start up cable modem and router.. after that, then turn your pc on and see if it recognizes...
is the adapter for a desktop to make wireless of a laptop, just curious..
Feb 21, 2008 | Computers & Internet
Linksys WMP300N Endless Bootup Loop
Disable or uninstall the Linksys software that manages and monitors the connection.
Use instead the Microsoft Windows Wireless configuration utility.
That's what I did and didn't get problem after.
Dec 30, 2007 | Linksys WMP300N Pre-802.11n Wireless...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
