Question about Frigidaire Refrigerators
Refrig Model # FRS26ZRG Ice maker is connected to a reverse osmosis. Has 60 lbs. psi. Was working fine now i hear the switch it sounds the same only no water comes into trays. also no water at door but it sounds the same when you press the dispenser.
  • 744 Answers
1. Check the water line to be sure it's clear, unobstructed and that water is available (check your RO unit too)
2. Check the water filter
3. Check the water valve
Visit this site for more info and diagrams - www.appliancepartspros.com
Put in your fridge's exact model and examine the parts lists.
Posted on Aug 21, 2010
2014 Kenmore side by side refrig. Water comes out of the door fine. Will not make ice.Tried the reset button on the left by the bucket, took top of door apart to see if mechanism was froze up.
Hello Rhonda Cornett,
Okay... water at the wall is connected... good...
but now you have TWO solenoids at the ENTRY POINT...
It would have been nice to know if there is water in the tray...
or if it EVER WORKED... but whatever.
If you are NOT getting water in the ICE TRAY...
you need to check that wire is connected to ITS OWN SOLENOID... (ELSE: solenoid might be bad)...
You might be able to TEMPORARILY REVERSE the water valves
to see if the door service still works with the SUSPECT VALVE..
Still works ... Ice maker trouble...
Fails solenoid trouble (bad valve) replace!
Then restore EVERYTHING... (take pictures ahead of tampering).
That click (or thump) you hear whenever you fill your water glass.
Every ice-maker I've ever tampered with has an on/off switch..
Fill controls... and firmness settings of some sort...
Check'em all out before getting DRASTIC.
Not the correct ICE MAKER PARTS
(illustrative purposes only)
appliance part houses (sears = pricy (IMLTHO)).
Water Filters Lawn Garden Appliance Parts
Jul 08, 2016 | Kenmore Refrigerators
Ice maker mal-formed ice
no "slug" is available however you could just use a reverse osmosis diaphram pressure tank to boost the water pressure. you can also use a water supply tube to bypass the in-refrigerator completely.
Jul 22, 2010 | KitchenAid Superba Architect KSCS25IN Side...
What line do you tap into to add an icemaker to a GE Reverse Osmosis water system?
If you want the reverse osmosis water to go to the ice maker then you tap in to the line that feeds the spiget on the sink.
Mar 03, 2010 | General Electric Profile Smartwater Ultra...
I bought a new tank for my reverse osmosis water treatment and it did not come with directions. It's supposed to be ''charged,'' whatever that means. When I hook it up to my system it does not fill with...
Typically a reverse osmosis storage tank should have a precharge of approximately 7 psi. Depending on the make/model of your tank it may have a higher charge currently which would cause the tank to not fill. There should be a schrader valve on the bottom or side of the tank. Using a tire gauge and bicycle pump you should be able to check the current pressure in the tank and adjust it up or down to 7 psi.
reverse osmosis storage tanks: http://www.freshwatersystems.com/c-32-reverse-osmosis-storage-tanks.aspx
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
Nov 04, 2009 | General Electric FX18M GE SmartWater...
Ice Maker Not Working
Hi: A lot of reverse osmosis systems don't supply enough water pressure to the ice maker to fill. Contact your manufactrue of your reverse osmosis system and see if it works with icemakers. I thind usually the require at least 20-30psi. Or hook your refrigerator to city pressure to see if it works. Also I don't know if you have just an ice maker or a water dispensing side by side, or your water quality. If you just have an icemaker, most chlorine will evaporate before the ice is frozen, any odors in the water will still be there. Good Luck, Jeff
May 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Side by side refrigerator
The ice maker is not producing ice or not enough ice
production.
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Kenmore elite side by side refrigerator
do you hear the little click of the switch when you push the paddle?? Its likely that the microswitch had broken from its plastic mounts. Pretty common on this refrig. ill need the model # to be sure what kind it is.
Nov 19, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool gd5shaxkqoo side by side ice maker
Hi. It takes approximatly 3 days to fill the ice container. If it is filling it half way, it should fill it all the way. There is no reason for it to stop making ice unless a cube gets stuck occasionally. Try replacing the water filter. If you are using reverse osmosis to filter your refrigerator water then that is your problem. Refrigerator ice makers don't work well with most reverse osmosis systems. Good luck, Mack
Aug 14, 2007 | Whirlpool GS6SHEXNL Side by Side...
Refrigerators Logo
163 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
