Question about Bosch Nexxt 500 Dryer
We have a Bosch Nexxt 500 series dryer making a grinding noise. How do we get to the guides?
5 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: The dryer (Bosch Nexxt 500) makes a loud grinding
The noise could be your drum rollers need lubricant or replacement.
When the drum rollers get flat spots on them they will make a bumping/thumping type of noise.
The grinding noise sounds to me like the drum rollers are in need of lubrication.
Posted on Sep 26, 2009
Ranglo
  • 1194 Answers
SOURCE: Bosch Nexxt 500 series dryer, E:01 and lint light
This indicates the sensor near the lint filter gets too hot. This is usually caused by bad air flow.
Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting.
You may need to have it cleaned out. May be lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, there may be heat escaping somewhere within the dryer. This is only resolved by technician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Posted on Jun 27, 2010
SOURCE: my bosch nexxt 500 series electric dryer is not
We had the same problem. Cleaned out lint filter and still no heat. We took off the back (lots of screws and had to take top off to get back off). If you are looking at back - at the bottom left there was a red reset button and it clicked when we pressed it (when we pressed it again there was no click). Worked fine after. This solution came from internet. My brother-in-law changed setting to "extra dry"- we usually just used 20/40/60 setting. I think it overheated.
Posted on Oct 04, 2010
  • 39 Answers
SOURCE: Where do I find the
Have a Nexxt 3300 and believe yours is about the same so yes, several screws to remove from the back. Top also has to come off because two screws to the back are under the top. And for the top to come off the control panel has to be pulled away. Only four screws under four white caps to remove for panel to be loosened. The top is attached with two screws in the back and four nylon clips under the top. The red reset button will be easy to see after removing the back. It is attached to the heating element housing. It is not hard to do, just a pain to get to the reset button. Link to Bosch appliance website with give you a diagram to help. http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=WTMC632SUS%2f02&ESHOPTYPE=A Good luck.
Posted on Mar 02, 2011
Need to replace the foam strip that seals the front door on my Bosch 500 Nexxt series electric dryer....do I do this from the front?
Most likely yes. Get a good adhesive for it though and make sure it is dry before you close the door and before you use it.
Aug 12, 2013 | Bosch Nexxt 500 Dryer
Bosch nexxt 500 elec dryer has no heat to it
There is a switch located on the duct from the heating element. Which you are not able to reset, you have to replace it if it's defective. Do a continuity test on it and if there is no continuity then the switch has to be replaced.
Jan 04, 2012 | Bosch Nexxt 500 Dryer
Drum makes grinding sound when turned manually. Is it bearnings, belt, or other?
the grinding noise is probably the bearings as the belt usually squeels and then breaks.I m not 100% sure with your model # but some have wheels that the drum runs on and they will wear out after time ;and they also have a bearing in them. Replace the whole set of wheels if that is the problem otherwise the others will wear faster.good luck
Oct 07, 2010 | Bosch Nexxt 500 Dryer
Makes a grinding noise while rotating
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 25, 2010 | Bosch Nexxt 500 Dryer
Is it possible to reverse the doors on a Bosch Nexxt 500 series dryer? If yes, does it require a kit from Bosch?
yes ,it is possible,you don't require a kit from bosch,however,you will need to disassemble the machine.if you are not confident,get someone who is.
Oct 16, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Ticking getting worse!
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
edgfd
Sep 30, 2009 | Bosch Nexxt 500 Dryer
The dryer (Bosch Nexxt 500) makes a loud grinding noise when rotating. Any idea what this may be?
Sep 26, 2009 | Bosch Nexxt 500 Dryer
Dryer is making a whining or squealing noise when in use.
heatman101
789gdsf
Aug 07, 2009 | Bosch Nexxt 500 Dryer
Open Questions:
See all Bosch Nexxt 500 Dryer Questions
Bosch Nexxt 500 Dryer Logo
66 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
