Question about Mitsubishi VS-55601 55" Rear Projection Television
My Mitsubishi projection TV model# VS-55601 has as display problem. The picture is distorted into an "hour-glass" shape. Well, that the best way I know to describe it. The picture no longer fills the entire viewing area of the 55" screen. Will replacing the lamp fix this problem? I love this TV and don't want to just toss it out. Thanks!
  • Debi Aug 21, 2010
    Thanks for the speedy reply. I followed the link for the repair kit and will likely purchase it. Question, you advised, "also check the resistors as if they are short the ICs might blow again after sometime." how will I know if they are short?, And if they are ...does the convergence repair kit include resistors?
    Thanks
    Debi
  • Debi Aug 21, 2010
    Thank you. I will order the kit and report back.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue is with the failed convergence (STK) ICs which needs tobe replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime.
There are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 21, 2010
  • Rylee Smith
    Rylee Smith Aug 21, 2010
    Thanks for your reply Debi, it does include the resistors as well. You can check if the resistors are blown also you can take a multimeter and test them. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Mitsubishi VS-55609 distorted Picture Flickers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
May 14, 2010 | Mitsubishi VS-5059 50" Rear Projection...
Picture has color separation and halos. Picture distorted.
Your convergence is bad and you need to replace the convergence ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Apr 27, 2010 | Mitsubishi VS-55601 55" Rear Projection...
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
Wavy lines on Mitsubishi ws-a55
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 16, 2010 | Mitsubishi VS-55601 55" Rear Projection...
Mitsubishi vs 55601 picture has gone out. It was
I have found several of the vertical deflection caps to be off value as well as the vertical chip to be defective.First after pulling the chassis (mark plugs and sockets that have no id numbers with a mark a lot) look with magnifier around vertical and hi section for circuit board cracks that need resoldered.Hope this helps.
Technition
Nov 17, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Mitsubishi TV VS-55601S Convergence Problem
Convergence it dead.Must replaced convergence,know how to solders?Tries these websites for convergence kit.Tv repair World.com,or Tv Repair Kits.
I have a convergence problem on my Mitsubishi VS-55601
ICS with some resisters,tries these websites Tv rpair Word.com or Tv repair kits.
Nov 02, 2009 | Mitsubishi VS-55601 55" Rear Projection...
How do I deguassa VS-55601
Many manufacturers put a software degause feature in the main menu. There should be an option for deguassing, I am not a hundred percent on this model but if you look in your operations manual it will tell you if this option is available. If not you can purchase a deguaser at a local electronics supplier. It is basically a round donut shaped electro magnet use caution and follow the instructions. Remember in the future to always keep external speakers away from your TV sets..
Jan 27, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Televison & Video Logo
202 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
