Question about Refrigerators
Kenmore 596.711 refrigerator not coolinng, freezer is fine
    President:
  • 1,197 Answers
While you are viewing this answer..... click on the "My Profile" link to the top right of this screen.... once clicked it will direct you to your profile page where you can see your chat name that you had with me.... click on that chat and rate the solution i gave you....
Posted on Aug 21, 2010
  • SAM JAYANTH CHANDRASEKAR
    1. 1
      The
      first thing you will have to do is turn off the breaker that supplies
      power to the refrigerator or unplug it from the wall outlet. Either way
      will suffice, as long as you do not try working on your refrigerator
      while it is powered.
    2. 2
      jQuery(document).ready(function(){
      jQuery('#jsArticleStep2 span.image a:first').attr('href',http://i.ehow.com/images/a04/9e/ek/test-...');
      Defrost Timer
      Find the defrost timer. Depending on the make and model of your refrigerator, it may be found in one of the following areas:
      Behind the front grill in the freezer
      Behind the cover plate in the freezer
      Behind the freezer near the compressor
      Inside the temperature control console
      Check out the image for an example of what the defrost timer will look like.
    3. 3
      Once
      you locate the defrost timer, look on the timer and find the advance
      screw. Turn it clockwise until you hear it click. Turn the power back
      on to the refrigerator. If the refrigerator was stuck in cool mode
      previously, this will advance it into defrost mode. Wait for about 30
      to 40 minutes and then check it again to see if it advances back into
      the cooling mode. You will know when it begins cooling again, as the
      compressor will turn on.
    4. 4
      If
      after 30 to 40 minutes you discover that the defrost timer is not
      advancing, then turn the power off to the refrigerator and remove the
      timer. The plug that connects to the timer can only be connected one
      way, so it's not important to draw a wiring schematic for this job.
    5. 5
      If
      the timer did advance as it was designed to do, then you will now have
      to test the timer electronically. With the power off to the
      refrigerator, remove the defrost timer. Take the timer to a clean
      workspace.
    6. 6
      Set
      your multitester to read ohms. This is usually the RX1 or X1 setting
      depending on the model of tester. If you look at the defrost timer,
      there should be four terminals. Find the terminal that is labeled "C"
      or "3." If the timer is not labeled, look at the connector plug to
      determine which terminal gets connected to the white wire; that is the
      common terminal.
    7. 7
      Touch
      one of your tester's probes to the common terminal. Then, touch the
      other probe to each of the remaining terminals on the timer. As you
      touch the other terminals, one or two of the terminals (depending on
      the timer's current setting) should read "zero" and the remaining one
      or two should read "infinity."
    8. 8
      Turn
      the advance screw again until you hear the click and then reprobe the
      terminals. This time, the results should be reversed. The terminal(s)
      that read "zero" earlier should now read "infinity" and the other(s)
      should now read "zero." It the timer does not pass this test, then it
      should be replaced. If it does operate correctly, then return it to its
      position in the refrigerator. The problem with your refrigerator may be
      caused by another issue like a bad defrost heater or thermostat.
    Please do not forget to go to the "My Profile' link as described above and rate the chat i had with you.
    there seems to have been a disconnect.... please get back to the chat as you did now.
I have a Kenmore top freezer refrig, My freezer works fine. My fridgerator is not cooling. I can hear the fan running. What could be the problem?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 26, 2011 | Kenmore Top Freezer Refrigerator
Refergerator not coolinng but freezer working good on a side by side
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 25, 2011 | Kenmore Refrigerators
Hi I have a Samsung fridge freezer the fridge is not coolinng and the freezer is not freezing but the motor is going.Regards Maria
have a look here for
this guy has few videos with various diy solutions for samsung fridge freezers
Jan 27, 2011 | Samsung Refrigerators
Top Mount ReRefrigerator stops coolinng. The frozen items in the top freezer are softening. The bottom part of the refrigerator, though the dial is on high cool, it is not cooling--it is a bit warm. The...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 08, 2010 | Frigidaire FRT21P5A Top Freezer...
My kenmore top freezer doesnt work my
the refrigerator may need some refrigerant, it might have a leak.
Mar 06, 2010 | Kenmore 64722 Top Freezer Refrigerator
Refrigerators Logo
254 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
