My Nordyne s1ba/s1qa split system air conditioner runs but isnt cooling.
bobotfel
  • 236 Answers
SOURCE: Split System Air conditioner
If it is water leaking check the indoor drain pan if overflow with water.If the pan is overflow with water then you need to clean your drain pan and drain pipe. While the unit is operating check the drain pipe if water drip, if no water coming out from drain pipe you need to flush it with water to flush out the restriction.
Try also to check if no icing build in the evaporator fins. If icing is present then you need to clean your indoor evaporator pins and air filter. But if it is clean and still icing is present then your unit is out of gas.
Posted on Jan 29, 2008
  • 5 Answers
SOURCE: Blueway split system wall air conditioning doesn't work properly.
need to add refrigerant
need to check wheather the ampere is the same on the name plate
check the room temp. setting
check the setting of the timer
Posted on Jan 26, 2009
Johnny Reb
SOURCE: Remove and relocate split air conditioner
The simplest way of explaining this is as per the following. On your outdoor compressor unit there should be two pipes, one smaller diameter [high pressure] and a larger diameter pipe [low pressure]. Turn your A/C on inside the house and then shut off the smaller diameter pipe. Run the unit for a around 3 to 4 minutes and then check if the cooling is reducing from the unit inside the house. When you feel room temperature air [not cool] being emitted from the indoor unit shut off the larger diameter pipe and turn off unit. Isolate electrics, disconnect A/C piping and immediately seal the piping with good quality tape to prevent egress of dirt. When re-installing a quick purge of gas is usually only required to clear the lines if they were sealed properly and kept clean. Ideally running a vacuum pump is recommended but if care was taken then it may not be needed, as in many of my installations.
Posted on Nov 13, 2009
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
SOURCE: I have a TCL split system air conditioner with error code E2
I have the same problem with my TCL unit. I have had the Tech out to day and I am told it is an internal senor in the unit that fails. I am informed by the tech that this is a very common fault with the TCL unit. Also if you live in Australia like me prepare yourself for a fight with TCL due to them not liking to honour the 5 year warranty. I would not recommend this product to anyone
Posted on Oct 25, 2010
3 split units run from one compressor one is not cooling
If there is 3 indoor units from one condensing unit
(6 pipes at outdoor unit) this is classed as a multi unit
All units will run correctly as long as they all require same mode, cooling or heating, if one unit decides to heat it will shut down until master unit decides to heat then it will start, for each unit to individually heat and cool there would have to be 3 pipes to each indoor,
Dec 19, 2015 | Fujitsu 9RLS 9000 BTU Split System Air...
HOW TO CHANGE A FUSE ON NORDYNE SPLIT SYSTEM
if there is a fuse it will be on the control board inside the air handler. if there is no fuse then it would have ruined the control transformer.
Dec 02, 2012 | Heating & Cooling
Nordyne Split System Blower Won't Start
It's the fan motor. A relay problem would cause the motor not to run at all.
May 08, 2017 | Heating & Cooling
Split not cooling and not working on heat
make sure outdoor unit is running if it is may have low freon if not check power at outside unit
Aug 25, 2009 | LG LS092CE Split System Air Conditioner
Power light is flashing and it isnt working
A multi split system is it? One of the reasons why the light flashes is because one indoor unit is on cool and the other is on heat. Changing the one on cool (or on heat) will fix this. Both indoor units need to operate on the same mode.
Mat
Jul 20, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
273 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
