Question about Lexmark Office Equipment & Supplies
I tried to reinstall my print driver but I get this error message: can't create output file:c\drivers\printer\Z2300\instal\X86\instGui.exe
Ajkill
  • 2035 Answers
SOURCE: Drivers won't download
Use this link to download: http://www.download.com/3120-20_4.html?tg=dl-20&qt=abby&tag=srch
Posted on Apr 03, 2008
SOURCE: Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Posted on Aug 29, 2008
JT92677
  • 13 Answers
SOURCE: SSMMgr.exe
I don't know how long it takes for a solution to appear here. I posted one, then had to login, so not sure it got posted.
Anyway, the problem is the Windows firewall program, or any firewall program running on your local computer. The samsung monitor has two-way communication with the computer, and the firewall will stop the communication, which is why it appears to be non-responsive, when in fact it is disallowed from responding.
Turn off the Windows firewall and use a hardware router to isolate your LAN from the WAN. I posted a more complete answer, if it appears, then I won't need to elaborate further.
Posted on Nov 17, 2008
  • 10406 Answers
SOURCE: Printer cant communicate with computer
Connect the printer to a different computer, and see if it is auto-detected, or if the printer itself is "dead".
Try a different data-cable between the printer and the PC, to ensure that the data-cable is not the problem.
Posted on Mar 07, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: when trying to install Lexmark Pro7000 series, I
    Great job tracyb367!!!
    Posted on May 28, 2010
    Acer crystal eye webcam runtime error problem
    Try reinstalling your camera driver and application program.
    Mar 28, 2012 | Computers & Internet
    Tip
    Fatal error : HPZPRL01.exe while installing HP printer Software
    1. Perform System restore:
    If the printer software was previously installed on the computer anytime before or even if the original issue was anything else before this error, then try restoring the computer to the date on which the software was working. You can then do add a device from the installation screen. The printer would start working fine as the software would already be available after doing a system restore.
    2. Uninstall the complete Software.
    Perform L1, L2, and L3 uninstall. Then reinstall the s/w.
    3. Insert the CD & start the install, select custom install.
    Under options select only "HP Drivers (required)" in order to install only the print/scan/fax drivers. If drivers will be successfully installed, you can add one by one the HP software starting again the installation and selecting Install More Software button & install the software in this order:
    • HP Solution Center
    • HP Device Functions
    • OCR Software
    Do not install HP Participation Program or HP Customer Experience or HP Supply.
    4. Grant full permission to the system
    Right click on My Computer, go to properties\security\Group or user names\ select the customer’s user name & click on permissions. Click to select the Full Control check box under Allow, and then click Advanced. Check both the boxes under advanced window. Click OK & close all the windows & restart the PC. Install the software by following customer install method.
    5. Make sure that you have write access rights enabled for the following registry keys:
    • HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors\
    • HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2\
    • HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Print Processors\
    • HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Prrint\Printers.
    on Jul 03, 2010 | Office Equipment & Supplies
    Hello: I removed all installed printers from the uninstall list in control panel the other evening. Then I deleted two icons from the devices and printers window but they sometimes reappear. This time, I...
    Hi Edward
    The automatic reappear printer problem its come when you are connect to two and three computer in same network, when the network on the automatic search the printer in network if you install that printer in any other PC so automatic the printer is add in your printer list.
    For installing the printer not nee to delete the all printer, put the installation CD in Rom and click the setup.exe
    Cheer
    Jul 11, 2011 | Xerox Phaser 6180N Laser Printer
    Using Windows 7, Trying to install printer, Brother MFC-240C. When computer starts or restarts Small window reads: Failed to start the ControlCenter. The required registry information is missing. Please...
    After doing a bit of reading, it seems the Brother MFC-240C model is discontinued. I didn't see any support for windows 7, so what we can try is changing the compatibility.
    1) Uninstal the suite/drivers, then restart your computer.
    2) Reinstall the suite/drivers and restart your computer once again.
    3)Look for BrCtrCen.exe in the directory of where ever the suite is installed.
    Should be either
    C:\Program Files (x86)\Brother\ControlCenter3\BrCtrCen.exe (for 65 bit windows)
    C:\Program Files\Brother\ControlCenter3\BrCtrCen.exe (For 32 bit windows)
    4) Right click BrCtrCen.exe, go to compatibility options and set the compatibility to vista.
    Information source:
    http://www.sevenforums.com/drivers/6086-brother-mfc-240c.html
    Mar 28, 2011 | Office Equipment & Supplies
    I am trying to download the software for my lexmark 9350 printer from lexmark website, I lost my disc from the original set up. When i try to open to install the download I get an error message "can't...
    look in add/remove programs and delete previous versions of the program and the drivers and then go to a website called freeware files.com and download the drivers from there... then reinstall the drivers to your pc...
    Nov 23, 2009 | Lexmark X9350 All-In-One InkJet Printer
    Mar 05, 2008 | Lexmark P4350 All-In-One InkJet Printer
    Lexmark X5150 driver download
    please try these steps
    1. Reboot the PC.
    2. Make sure the printer is selected as the default printer in the Printers folder and try to print again.
    3. If printing fails, you will need to download the printer driver again. To do this:
    4. Create a folder on your desktop and call it Lexmark.
    5. Go to our Drivers & Downloads center. Note: The name of this page/site may be slightly different in your region/country.
    6. Click Printer Driver.
    7. Select the Related Product Name from the drop-down menu.
    8. Select your Operating System from the drop-down menu.
    9. Select the desired Language from the drop-down menu.
    10. Select the latest Driver File and click on the File Name to detach it to the Lexmark folder on your desktop. Wait for the download to complete.
      Important: Make sure any copies of the driver from earlier installations are uninstalled before you install the downloaded version.
    11. Install the downloaded driver as follows:
    12. Open the Lexmark folder and double-click on the downloaded file.
    13. When the WinZip Self-Extractor screen appears, click on When done unzipping file open: <the printer file name>. (The printer file name will appear beneath this option.)
    14. Click Unzip. The installation program should autorun. Follow the on-screen prompts to install the printer.
    15. If the installation program does not autorun, locate the newly created LXK___ folder for Setup.exe and double-click on it. An installation program will run. Follow the on-screen prompts.
    16. If you are prompted to install the printer for all users, click Yes.
    17. When the installation is complete, restart the PC.
    Jan 26, 2008 | Lexmark X5150 All-In-One InkJet Printer
    Dec 26, 2007 | Office Equipment & Supplies
    47 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
