Question about RCA F31672ET TV
RCA F31672ET TV
I don't have the manual. What is the combination (channel?) to change it to work with a DVD?
  • Anonymous Nov 28, 2008
    I tried the tv/video button but the tv still will not connect with the signal from the vcr/dvd player. I don't have the manual and am using a universal remote because I found this tv.
    It works fine otherwise but will not connect with my vcr/
  • 4 Answers
It should work with the input button on your tv remote
Posted on Dec 20, 2008
I too had the same pbm. Press the input button in the universal remote by which it toggles to the dvd mode.Hope this works
Posted on Dec 06, 2008
  • 71 Answers
Use tv/video switch
Posted on May 03, 2008
How can i hook up an external dvd player to this tv? i followed the dvd player instructions but i cant get it to play...i can only hear the sound
On the front you have a yellow white and red port. Use the RCA cables from your DVD player to the front of this T.V. Change the T.V. input probably with the remote or just the channel buttons. If this doesn't work, use different RCA cables because the one's you're using may be bad.
Jun 17, 2011 | Sylvania 6520FDE 20 in. TV/DVD Combo
I have an RCA F31672ET and it works perfectly on channels 51 to 98 but will not recognize the rest of the spectrum. I am on cable. Thanks.
Depends on how your cable provider is distributing the TV channels.
Channel 100 is the line into the Jumboband, and most providers don't distribute analog cable beyond channel 99 since it requires a different type of amplifier. They will generally use Digital Cable for higher number channels, which would require a converter box.
http://en.wikipedia.org/wiki/North_American_cable_television_frequencies
Who is your cable provider?
Apr 24, 2011 | RCA F31672ET TV
Suddenly, my whole entire RCA TV is all in Spanish.
Que lastima!
Try pushing the Up and Down channel buttons to get to the menu.
This works on some sets.
Jun 18, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
I have a rca tv model F31672ET. I do not have the
Check with the channel 00 good luck
Jun 05, 2009 | RCA F31672ET TV
Need to know what channel my TV needs to be on to watch DVD/VCR
The channel you use depends on how you have the vcr/dvd player wired to it. If you used a co-axial wire, then your tv should be on channel 3. If you used RCA wires, then you will have a button, either on the front of the tv, on the remote, or both that says "input" or "source". Pressing this will change the TV to the rca connectors. Try this and let me know if it helps :)
May 16, 2009 | RCA B27TF680 27 in. TV/VCR/DVD Combo
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
No sound
Clip R1915 and the sound will return. But you still have a Tuner to rework. See my solution with the power problem. just before this answer!
Oct 14, 2008 | RCA F31672ET TV
External DVD won't play - no manual available anywhere
The tv has a set of imputs for audio and video ,there is a posibility your dvd is not working right,you can also try a vcr by using the rca audio and video outputs of the vcr to the rca audio and video imputs of the tv,that will tell you if the dvd is not working ,the tv should have a switch selector for video and antena or have a channel below 1 called aux.
Oct 02, 2006 | RCA T13208 13 in. TV/VCR Combo
Televison & Video Logo
301 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
