First how is the computer connected to the printer (USB or wireless)? Next did you install the full software for the printer or just the basic driver? The software is available from
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx472#DriversAndSoftware . What OS are you using? What firewall software do you have installed?
First, if you are using a USB cable, try a new cable of less than 6' in length.Try a different USB port and a direct connection if you use a USB hub. Scanning requires bi-directional communication between the computer and the MX472. Printing doesn't need the same level of two-way communication.
For a wireless connection, you'll need to ensure that your firewall allows for the bi-directional communication on all of the relevant ports.
Next launch the IJ Scan Utility software. This is how the Canon all-in-one talks to the computer. Put your document/picture on the scanner glass face down. Select the Scan from Computer tab; it's the first tab. Try scanning manually after setting the desired scan software, scan DPI and destination. See
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx472?pageKeyCode=ekbresults&CONFIGURATION=1011&PARTITION_ID=1&secureFlag=false&mType=PIXMA%20MX&mName=PIXMA%20MX472&TIMEZONE_OFFSET=&USERTYPE=1&CMD=VIEW_ARTICLE&ARTICLE_ID=53332 for some details on these settings. This manual scan will work with any connection type between the computer and the printer, if the ports are not blocked by a firewall.
If you wish to use the Scan from the Operation Panel option, you need to have a USB connection between the computer and the MX472. You also can't set this from the Image Garden software if you launch that first. After doing your first manual scan and getting the initial settings, select the Scan from Operation Panel tab. Set the Auto-Scan options as per your initial scan settings. Click OK to save the settings. Now, try launching the scan from the LCD panel or Scan button on the all-in-one.
I hope this helps. If you are using a network connection, please add a comment with the firewall software for details on how to allow the scanner to communicate to the computer.
