Question about Russell Hobbs RH-HB3 Handheld Blender
It runs until I put it into the liquid then the detachable blender stops working.
  • Russell Hobbs Master
  • 17,130 Answers
It seems that the power is low on to the motor and so will have to see if there is a friction on the drive.
If not check the motor for poor brush connections that reduces the power when the load is applied.
The other problem is if cleaning can solve it will be the best as a replacement may not be feasible with the cost and availability.
Hope you try this tip.
Posted on Aug 21, 2010
My kitchenmaid pitcher is stuck on the mixer. it still mixes, it won;t detach
The coupling on the motor has become bonded to the coupling on the beaker. Maybe it was moving about excessively and the 2 plastic parts have fused together. You can expect to have to replace the motor coupling and at the least the blade assembly or possibly the whole beaker depending on model. Knowing what you are up for needing to replace now if you wish to get it off put a litre of water in it, put the lid on and turn it on high and wobble, wriggle it about until it is able to be lifted off.
Aug 26, 2016 | KitchenAid Blenders
Base of my blender won't detach
please use the WD-40 for to loose and Ready.go www.40company.com
God bless you
Nov 06, 2013 | Cuisinart BFP-703CH SmartPower Duet...
How do i get the bottom off the blender jar?
The best way that I've found to remove the bottom from the blender jar is to put the blender jar back on the blender base (make sure it locks in place) and then turn the jar to the right. You'll feel the jar detaching from the base. Once it's loosened up, remove from the base and finish turning the bottom, manually. Before I found this method, I had tried everything to get the plastic bottom detached from the jar. Without removing the bottom, there's no way to clean it properly and rather than be unsafe I'd need to throw the whole works in the trash. But the method I've described above works every time!
Aug 13, 2011 | Jenn-Air JBL800 Work Top Blender
My breville blender model#bbl600xl leaks every time I put liquid in it, the gasket is in place and it is tightened as much as possible, what is the problem.
It leaks if you over tighten it. So try to just do it finger tight. I was having the same problem, once I eased off on the tighten if stop leaking. I assume you are getting it correctly aligned as that can be the other issue.
May 14, 2011 | Breville BBL600XL. 5-Speed Blender
My rarely used Sunbeam Blender Model #4181 stopped working
It sounds like one of a number of things...
* The contacts in the switches fried
* The motor itself fried
* The controller section fried
If you saw smoke, something fried... probably cheaper to simply replace the unit. Even if it still worked, it's a 120V electric appliance used with liquids, and I wouldn't trust it... I'd hate to hear that your blender started a kitchen fire.
Mar 22, 2008 | Oster 4134 / 4126 Classic Beehive Work Top...
Osterizer Blender
You can replace the Osterizer "Standard Blade Assembly" (which includes a new rubber gasket) without buying a new and expensive glass jar. See http://www.householdappliance.com/blenderparts.html or one of the other appliance repair parts websites. After 20 years of use, it's time for a new blade and bearing.
Feb 27, 2008 | Blenders
Blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Jan 14, 2008 | KitchenAid KSB5 Professional Stainless...
Base leaks heavily when any liquid goes in!
make sure the seal gasket is between the base and the blade base- 99% it will solve your problem!
Aug 27, 2007 | Tefal MagiClean Work Top Blender
Russell Hobbs RH-HB3 Handheld Blender Logo
100 people viewed this question
Top Russell Hobbs Blenders Experts
eyecam
Are you a Russell Hobbs Blender Expert? Answer questions, earn points and help others
