Question about Dometic 57915531 Air Conditioner
A/C WILL NOT SHUT OFF - Dometic 57915531 Air Conditioner
  • Dometic Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 22, 2010
Pull the keys radio never shuts off, I replace the fuse because it was burnt out.
radio will not shut off when car turned off - Car Forums and ...
www.automotiveforums.com > ... > Chevrolet > Cavalier
I have this anyoing problem..when i pull the key out of the ignition the radio ... They could not wire it so that when you opened the door, it would shut off. .... I NEVER had to do anything with the airbag wires or shut the airbag off or anything!
07 Silverado Will Not Shut Off With Key Removed - 1999-2006 & 2007 ...
www.gm-trucks.com/.../115642-07-silverado-will-not-shut-off-with-key...
Jun 27, 2010 - 14 posts - ‎8 authors
The only way I can shut it off is to pull the fue... ... It runs perfect as if I never shut itoff. It is not dieseling it runs like the key is on. The complete vehicle shuts down like it is off ie all dash lights, radio, go of and it will not allow the ...
VW Jetta MKIV/MK4: Stereo doesn't shut off with car 'Volksw
Dec 30, 2015 | Cars & Trucks
New computer will not shut down
Try going to your power option in the control panel. Make sure that hibernate is disabled, change what power buttons do. Make sure when you press power button it is set to shut down. Choose when computer sleeps as never.
Oct 07, 2017 | ASUS Computer International Computers &...
Husky Air Compressor wl660800AJ...my problem is the compressor will not shut off after it reaches the shut off pressure it keeps running? checked and supply tube clear....
Hello
Replace the pressure shut off switch.First drain the tank and shut off all power.Remove switch and inspect for any debri or water in the tube to the switch.
Also check the settings.max i think is 150psi.So it should fill to say 145 and shut off.
Sep 26, 2011 | Air Tools & Compressors
Windshiled wipers will work on the intermittet stage for about 10-15 minutes then automatically goes to regular speed and will not shut off. When stop vehicle and shut engine off and let sit 15-20 minutes...
windshiled wipers will work on the intermittet stage for about 10-15 minutes then automatically goes to regular speed and will not shut off. When stop vehicle and shut engine off and let sit 15-20 minutes wipers will shut off. When needed again same thing will happen This is on a 2003 Chevrolwt express Va
Feb 09, 2010 | 2003 Chevrolet Express
I cant turn off my shut off valve that goes to my
Hi!
Are you talking about the gas shut off valve or a water shut off valve(if you have a boiler)? Either way if you can't shut it off you need to get it replaced. Good luck!!
Dec 31, 2009 | Heating & Cooling
Shut down computer but some lights stay on
Your are not "shutting down" the laptop. It is going into "Stand-by" mode.
#1:
When you want to shut down,
select [Start]
then select "Shut down" and not "Stand-by"
The power button will also work.
#2:
Press the power button and nothing else.
The laptop will log you OFF and "shut down"
Nov 08, 2009 | Toshiba Satellite A135-S2386 Notebook
I cannot shut down or restart my PC using the start menu prompts. The only way to shut her down is a hard shut down (manually turn her off).
There is a program that is failing to shut down in general, which is delaying the computers ability to shut down.
The next time you shut down, make sure you have no programs open. Then, while attempting to shut down, wait until Windows pops up window asking you to close a non-responsive program. When it does, take note of the program that it mentions, then close it and see if Windows shuts down. Note: sometimes this takes a really long time.
Try re-installing the non-responsive program and see if your computer can shut down normally again.
Aug 07, 2009 | Acer Computers & Internet
E-machine computer will not shut down
When you say "it will not shut down", are you referring to clicking on start and then shut down?
You could try forcing a shut down by holding the power switch down for about 5 seconds.
Jan 18, 2009 | E-Machines eMachines Desktop PC
My computer does not shut down
Ok
Gonna try and teach you some basic programming :-).
What the following will do, is create you a Desktop Shutdown Icon, which when you double click on it, will hopefully shut down your PC rather then restart it.
So here's how to do it :-).
1. Right click on your desktop and select new > shortcut.
2. In dialog box type “shutdown –s”
3. Click next to continue and then type a name for shortcut (IE Shut Down PC) and click finish.
Now you should see the shortcut on your desktop and will hopefully solve your problem.
Dec 08, 2008 | Computers & Internet
Dometic 57915531 Air Conditioner Logo
41 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
