Question about Microwave Ovens
The trash compactor won't open and it locked shut. When the dial is on the "ON" position, the unit just hums.
  • Microwave Ovens Master
  • 17,129 Answers
Check the mechanism for the door failure as the link could be caught up . open the top cover and find this out.
The hum could be the failure of the capacitor which could be short.
The microwave will not work then, so replace and check this out.
Posted on Aug 21, 2010
Shm1816s Samsung microwave oven wont shut off All lights off turn table not turning but you can hear the humming. the turn table plate gets very hot.
if the turntable is getting hot it means that the microwave is working but as the turntable is not turning , it means the adjustment of the door lock of your microwave may have become improper due to use.may be it got damaged.
call the technician of samsung microwave ,he will open the cabinet of microwave and make the adjustment of door lock proper.
Thanks
Nitin
Oct 19, 2013 | Microwave Ovens
Door won't stay shut, microwave will not start
Contact the maker or Google the model number for "parts"
That part likely will require the unit to be taken apart to replace it.
Jun 16, 2012 | Jenn-Air Microwave Ovens
I have a GE Spacemaker microvave oven that was working perfectly for the past 4 years. When installed, we were told that the outlet did not work, so to get the microwave working, the cord was pulled out...
Perhaps the microwave's main supply fuse has blown.Open the cover & check it in the power supply section.Be careful & discharge the big capacitor first as there is very very high voltage present inside even after switching off.
Mar 07, 2012 | GE Spacemaker Over-the-Range Microwave
Microwave buzzes when off
This is the power transformer humming, sometimes when transformers get older you get vibrations in the windings due to magnetic fields generated within the transformer which causes the humming noise, It's more annoying than anything and won't affect the operation of the microwave.
Mar 06, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
After the GE JVM1190BY002 Microwave stops its microwave sequence the fan motor above the touchpad just sits and hums but doesn't shut off.It still heats food corectely and it stops humming when I open...
You should first be sure your filters are clean and that your ductwork is clear.
See this link for a bulletin that may address your problem.
Otherwise, see this link in case you have a sticky door switch or relay.
You can find helpful GE exploded views and order GE parts here, and download GE owner's manuals and installation instructions here.
Oct 20, 2011 | Microwave Ovens
Kitchenaid trash compactor bought in 2000; no model/serial number found. Compactor was stuck in partial down position; worked the drawer out and found cotton fibers wadded/stuck at top of the up/down...
at the top, above the ram, there are two switches. One is the reversing switch (should have 4 wires), the other is the stop switch (2 wires). I suspect that the switch arm is bent, due to what you just described, and fails to activate the switch to stop the motor when the ram is at the top position.
May 24, 2011 | KitchenAid Microwave Ovens
My Jenn Aire Trash Compactor Model TC507B1 does not turn. When I turn the start knob to on position, the compactor makes humming sound, but it does not seem that the ram is moving. I have checked the...
Sounds like the motor that turns the reduction gears which ultimately pushes the ram could be seized up. If an object was jammed inside which was to much for the motor to handle it could cause it to draw too much current seize up the motor.
Jan 24, 2010 | Microwave Ovens
My Jenn Aire Trash Compactor Model TC507B1 does not turn. When I turn the start knob to on position, the compactor makes humming sound, but it does not seem that the ram is moving. Now, I can't even open...
We had the very same problem. Pull the compactor out and unplug the unit. Lay it on its side and remove the bottom. This will expose the chain and gears. On our unit, the plastic sprocket was broken. This part turns the chain to make the ram go up and down. When I called about a local location to buy a new part, I was given 1-800-688-9900 to phone for help. Tell the automated service you want "parts" and you will get an operator. I described the part and she said that is was no longer made in plastic -- it's now metal. The part number she gave me was #675370. I could've ordered the part through them and would receive it in 3 business days. With our zip code, she was able to give me two locations in our area to get the part. One place had the plastic part -- no thanks. The other place was able to get the part in the next day. Hope this helps more than solutions 1-3.
Jan 23, 2010 | Microwave Ovens
Humming ge sapcesaver microwave
During operation, most of the built-in models have a panel that tilts out while the exhaust fan is on. When cooking is done, the exhaust fan shuts off and the panel retracts to its normal position. With the fan & microwave motor off, the hum is easier to hear. Look closely at the top panel the next time you hear the hum, and you'll probably see that it's retracting.
Jan 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
70 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
