Question about John Deere Gilmour Traveling Sprinkler - 4010j
Nylon gear is worn, slipping under the slightest stress! Need replacement parts.
  • 43,501 Answers
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Posted on May 19, 2011
Cant select gear sometimes on my 1987 t25 1.9 dg
Linkage is likely damaged/loose or worn.
Start by looking at connection at transmission for disconnected/loose parts and work forward.
Most likely issues are universal joint rotting out, "cup" on transmission fracturing and worn out nylon ball on shifter rod under cover in floor.
Another common problem is loose adjustment plate under cover on floor as well.
Search for issue and re-post specific question when you find something.
Oct 07, 2013 | 1986 Volkswagen Wagon Camper
Loud banging during kneading
you are right.for further help check this link.
www.repairclinic.com
Aug 29, 2008 | Breadman TR875 Bread Maker
Nylon drive gear worn on one side
I have been told by the manufactutere that they do not make any replacement parts for their shredders. If it is less than a year old they will replace it.
Jun 20, 2010 | Aurora Electronics AS1018CD Shredder
Headlamps are stuck in the up position. There is clattering, like a motor gear slipping, whenever lights are turned on or off
Hello, my name is Ben. You may know this is a very common problem in Corvettes. Chevrolet uses plastic gears in the headlight motors and the gears fail over time. You headlight motors are going to need to be rebuilt. There is a company that makes a brass gear to replace the plastic gear. I'm not sure if you are wanting to do the work yourself or having it done. If you are mechanical and feel you can accomplish the repair, I can send you the procedure.
Feb 26, 2010 | 1993 Chevrolet Corvette
Our power window gears do not work. motor works, window slips. do we change the whole motor?
Yes, change the motor out. It has a plastic/nylon bushing in it that some parts houses do sell. However, most parts stores now sell lifetime warranty motors, if youre going through the trouble of taking the motor of to replace the bushing better to replace the entire motor so if the bushing or motor goes bad you get a free replacement.
Dec 07, 2009 | 1991 Ford F150
Oster A5 clippers are slow and vibrating noisily even without a blade attache. Any ideas what could be wrong with them please as I have a dog only half clipped at the moment. Thanks
If the nylon lever (the tab that moves the blade back and forth) is not moving with the blade off, or only moving sometimes, chances are that you have a stripped bakelite gear. Take the two screws out of the cover plate and remove it. Remove the lever (the nylon part that moves the blade) Remove the link (the metal part that the lever connects with). Remove the bakelite gear (the part that the link fits down over). You should then be able to see if the teeth are chewed or worn off to the point that the armature gear will not turn the bakelite gear. If that is the case, replace the gear. Amazon carries both single speed and 2 speed gears under Oster A5 clipper parts. All these parts should have a light coat, where they move, of lithium grease, and the two pads (one on each side of the lever) should be oiled. You might also check the condition of your brushes (under the caps on each side of the clipper. Take cap off, remove cover from brush, remove spring and brush to see how worn they are).
Good luck.
Aug 10, 2009 | Oster Golden A5 2-Speed Universal Motor...
Slips out of gear (while driving)
sounds like the synco gears might be going in the tranny,they are only soft gears and gets damged easily campared too the rest of then or the forks are worn in the tranny they have nylon on the forks, and sometimes wears down as well
May 10, 2009 | 1987 Chevrolet Blazer
Slipping clutch
clutch basketYou will need the fibre clutch plates and I would be replacing the clutch springs because the 400 had weeker springs than the 450 (04YM). Also check if the metal plates are blue this is a sign they are bernt and they may need replacing if it has been slipping for a period of time. Use 10w 40 oil. Motul or Motoex oil they are good and go genuine some non genuine plates can swell and cause drag. Sometimes the basket may have small wear marks on the fingers. If it has you can clean them up with a file but dont take to much off. The only other reason you would replace the basket is if the damper rubbers between the basket and big gear are worn.Try and move the gear and hold the basket, if the gear moves the dampers are worn and need replacing, I think you can get the dampers seperate. If you go to a good Gas Gas dealer you wont get riped off, I would take your plates in and ask for the mechanic for advice and not the parts person.,,,
Nov 10, 2008 | 2003 Gas Gas EC 400 FSE
Kitchenaid professional....
It sounds like you need to change the brushes. You can look up your parts manual online here and then buy them online. Should be under $10.
Aug 16, 2008 | KitchenAid KSM50PR Professional Series...
John Deere Gilmour  Traveling Sprinkler - 4010j Logo
269 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
