Question about Sewing Machines
I have a Kenmore 36 machine and the feeder foot is not working. I recently moved to Germany and there is no place near me that I can take it to have repaired. I had the machine serviced about 10 months ago in Georgia. Is there something I can try myself without making things worse?
    Genius:
  • 1,788 Answers
Go to www.tias.com and you can buy one for $17.
Posted on Aug 21, 2010
How to thread kenmore sear roebuck sewing machine model 158. 1789181 got at auction no books
Sears carries a lot of manuals for their machines, although usually not free. In the meantime, there are many threading videos that demonstrate machine threading. Machines of similar models will thread similarly.
Threading mom old kenmore sewing machine
Kenmore 158 17550 Sewing Machine Tutorial
Probably best to raise the presser foot when threading so the thread will seat in the tension disk.
Before trying to sew, be sure to oil your machine with fresh, good quality sewing machine oil. Open the top, the side near the needle bar, and turn it on its back to get the underside. Place a couple drops of oil every place that metal rubs on metal. Adding hot air from a handheld hairdryer will make the oil effective quicker.
Be sure to install a brand new needle and use good quality thread--not old or bargain bin variety!
On the top left, there is probably a push button. This is the presser foot pressure adjustment. When the machine is stored, this pop-up button should be released (press down on the outer ring). Being stored with the pressure full on will eventually compress the spring that provides the pressure. Also, be sure to store the machine with the presser foot in the down position (preferably on a piece of scrap fabric). Avoid running the machine with the presser foot in direct contact with the feed dogs as this will wear the feed dogs and also create grooves in the presser foot.
Kenmore 158 1601 Sewing Machine Cleaning oiling and Maintenance
Jul 29, 2016 | Kenmore Sewing Machines
The Feeder Dogs are not moving forward or backwards on my sewing machine.
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
Mar 19, 2013 | Kenmore Sewing Machines
Hello, I have a kenmore sewing machine model #385.19233 . It is not broken, what i need is someone who can tell me how to get this machine to do free motion sewing. I hope you can help me.
If your machine has an embroidery foot, this will allow you to free motion embroidery. The embroidery foot will be positioned close to the fabric but will not hold the fabric in place.The presser foot must be down so that you will have the correct tension. Once the foot is on, the presser foot lifter is in the down position, then it's up to you to guide the fabric under the machine in the pattern you want. I advise a regular straight stitch with about 6-8 stitches to the inch. Move the fabric at a medium speed under the foot. If you move too slowly the stitches will be too close. If you move too quickly you'll have HUGE skips in your stitches. The main thing to know is that you can't use a regular foot because it will hold the fabric in place, even if you lower the feed dogs. When I free motion, I use the embroidery foot and keep the feed dogs up just to give a little resistance but NOT to hold the fabric in place. I love doing the free motion and I hope this helps you get started. If it helps you, please come back and rate my advice. Thanks!
Aug 01, 2011 | Kenmore Sewing Machines
My janome machine sews on the same spot, the material does not move. I have moved the feeder foot but nothing happens.Sometimes the feeder foot stays down.Idont have a manual for this machine.Igot it as a...
the feed dogs in the needle plate area are what moves the fabric while the presser foot hold the fabric
if the feed dogs are not up, check to see what position are in,,they should be in the bobbin area
if you can't move them they should be checked at a repair shop
Nov 20, 2010 | Janome Sewing Machines
Feeder not moving thread is bunching up How do
I took off the foot, plate and where the bobbin is kept. Cleaned it out and there was a thread that was caught there. I put it back together and it worked fine.
Thank you
Patti
Oct 29, 2009 | Husqvarna Freesia 415
My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
May 14, 2009 | Sewing Machines
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Feeder feet under presser foot clicked down not able to get back
The switch for the FEED DOGS is on the left side of the machine.
Mar 19, 2009 | Kenmore 15343
Sewing machine
You may need to remove the shank shaft w/screw driver which is where the foot attaches to and replace it . I had a problem when I had to attach a ruffler foot. A little practice w.this can save you a lot of repair bills. Most Janome dealers can repair ths too. Kenmores are made by Janome.
Oct 17, 2008 | Kenmore 15516 Mechanical Sewing Machine
Kenmore sewing machine # 385.17626 feed dogs not advancing fabric. Appear to move up and down, but not forward to back.
I had the same problem and had recently posted my own message, with no replies. Took it to a repair person and he fixed it at no cost - it was stuck in reverse because the mechanism(s) were all gunked up. Take off the accessory box on the machine and the bottom plate. move the mechanism so they move freely and take out any gunk you see. The feeder dogs should now move back & forth in addition to up & down, feeding the material properly
Jun 21, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
87 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
