Question about RCA R52WH73 Projection Television
The projector, it gave out how to change it - RCA R52WH73 Projection Television
  • RCA Master
  • 8,617 Answers
You can get assistance with that from www.tvrepairworld.com they also have the replacement CRTs ( Picture Tubes) for your model.
Posted on Aug 21, 2010
I have a Dell 4100MP that works except after 1-1/2 hours or so the picture inverts and the colors change so everyone is Blue. I can correct it by going into the menu doing a factory reset then working
your projector is having an electronic part malfunction, this is shown by the time frame you gave on your question and the reset option that usually fixes it. I am not all too familiar with a Dell projector , but check if the system has a CMOS battery that needs to replace and a capacitor that over heats causing the malfunction, better take system to a qualified electronic technician or a Dell service center.
Oct 22, 2014 | Dell 4100MP Multimedia Projector
Tip
Toshiba TDP-P9 Lamp time reset
I had sleepless nights with my customers TDP-P9 projector where I changed the lamp.
The lamp timer resetting gave me headache but now I finally solved the right combo:
1: Unplug the power cord
2: Hold down 'On/standby' 'Input' and 'up arrow'
3: While keeping the buttons pressed, insert the power cord and wait for the projectors led's to flash briefly and then power button to keep illuminated and then starting to blink.
4: Release the buttons and power on, it should now have 0 hours in the timer.
on Apr 06, 2011 | Toshiba TDP-P9 DLP Projector
I have a Sony VPL-CX61 Multimedia Projector. I just changed the lamp and I cannot get the "please replace lamp" message to go off.
When you use a projector it automatically keeps a timer of how long the lamp has been used for. The message that comes up on screen saying "please replace the lamp" comes up not because it's some how sensing that the lamp is getting old, but because the lamp hours gets to a certain number (usually up around 1500 hours). Because of this when you replace the lamp you need to reset the lamp hours counter, or the projector doesn't even know you've changed it. Every projector does it this way, and they all do it a different way, I googled the model you gave us and found this set of instructions on how to do it, so give it a go.
Reset the lamp counter hours of operation for the projector SONY VPL-CX61
Using the remote commander while the unit is powered up, press "ENTER", "ENTER", "LEFT"
and "ENTER" in sequence. A prompt will appear on the screen asking if you wish to enter the factory mode.
Press the "UP" key on the remote and the unit is now in service mode. This sequence will add two new groups
to the customer setup menu. Press the "MENU" button to view.
Whenever the lamp is replaced, the lamp timer should be reset. With the unit in the "factory" mode, press
"RESET", "LEFT", "RIGHT" and "ENTER" on the remote commander. Verify the lamp hours have been reset to
zero in the service menu.
Hope this worked for you,
Mar 23, 2011 | Sony VPL-CX61 LCD Projector
I have a Panasonic PT-AX200 LCD Projector. It is mounted on the ceiling. I need to know how to focus the screen without climbing up to the machine itself to do it. Is there a way to find the focu using the...
I'm afraid, no remote option available to focus image of this projector and has to do manually. Check projector Menu and select Test Pattern for optimum focus and it would be one time job if projector and screen distance has not been changed.
I'm not sure about the advice regarding "color management" as it has nothing to do with focus.
User manual link is also broken and take you no where.
Aug 11, 2010 | Panasonic PT-AX200 LCD Projector
Projector gave a message that it was overheating and then shutoff
chek if all fan are running. check if any extrange thing is in the grids. anyway is better to take it to service.
Apr 20, 2010 | Epson - PowerLite S1+ Multimedia Projector
New Bulb (30 hrs). Screen flickers after 10 minutes, color changes with green tint, then bulb shuts off.
Hi, I had a similar problem - the screen flicked through blue, green and red sometimes with a slight ticking noise. The problem seems to be that the colour-wheel is getting stuck - the first time this happened I sent it back to optoma who gave it a clean - it has happened again since thouegh and I just took the case off (you'll be able to see the colour wheel under a black plastic flap - remove the flap) I then used a cotton bud (q-tip) and turned the colour wheel whilst lightly pressing the cotton bud against the wheel - I also gave everything a blast with a can of air. My HD72i is ceiling mounted - optoma suggested putting the hoover pipe across the vents every now and then to keep the dust down. Essentially it's dust that is stopping the movement of the colour wheel.
Hope this helps.
Jonathan
Oct 21, 2009 | Optoma HD72 Multimedia Projector
Scout lightware projector. I have lost the original fuse.
The projector takes a 5 amp fuse. The manufacturer gave me the information.
Dec 04, 2008 | Lightware Scout Multimedia Projector
Code password
Hi there
Here is your password for the above code you gave -
9097
May 10, 2008 | BenQ MP610 Multimedia Projector
HP vp 6120 Projector
Hi there
Have you reset the lamp timer ?
If you have and the problem stil occurs you will have to replace the Ballast ( lamp's powersupply ) This is a very common problem with this specific HP model.
Dec 29, 2007 | HP Digital Projector Vp6120 Multimedia...
RCA R52WH73 Projection Television Logo
20 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
